Bulletjie Posted September 24, 2010 Share Posted September 24, 2010 Hi, Can anybody help me i am fitting a 3.9 efi engine into my defender and all wwent well untill now.Im battling with the wirring for the white and brown plug.Does anybody know where the wires need to go.I have figured out some of the but if somebody have the wire colours and where to put them i will very gratefull Thanx Bulletjie Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 24, 2010 Share Posted September 24, 2010 Main wires are as follows : The "Big" Brown wire goes to a decent live, this draws the main power which can be more than people 1st think The White & Purple = Fuel Pump Live, the other wire from the fuel pump goes to a GOOD Earth on chassis Then there is a smaller White - this must go to a "Live" but one that is "Switched" - ie only live when the ignition is "On" - do not get this muddled up with 'Cranking live' = live when cranking and then dead afterwards, thuis must be live AFTER Cranking has finished and its running. Inside the engine bay the single black & white wire having a in line resistor (which must be fitted), looks like a cumputer black chip with terminals ends both sides this connects to negative side of the coil Also look through the loom, there are some eraths that go to the back of the heads, these are essential and must be decent clean earths Also run an extra earth from engine block to chassis =- again ensure fresh metal to metal and tight as a tight thing That should make it run. If its from a CAT V8 change the tune resistor for a green one too Also fit the road speed transducer, as without it tickover and over run to stationary can be poor or erratic to bad HTH Nige Quote Link to comment Share on other sites More sharing options...
Bulletjie Posted September 24, 2010 Author Share Posted September 24, 2010 HI, Thanks is that all i need for it to run?This comes out of a discovery 3.9efi.It has the brown and white plug i will try to attach the photos then you can see if it will work. Thanks a mil anyway Bulletjie Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 24, 2010 Share Posted September 24, 2010 Quote Link to comment Share on other sites More sharing options...
Bulletjie Posted September 25, 2010 Author Share Posted September 25, 2010 But my white plug only has 24 pins and the brown has got 7.The brouwn plug i have managed to sort as the fuel pump feeds from there but the white plug with the 24 pins is the problem.I also find no white wire to go to the ignition all the wires have colours or white with colours. Quote Link to comment Share on other sites More sharing options...
