ibexman Posted September 24, 2010 Share Posted September 24, 2010 My headlamps have only a normal 3 spade plug but when u switch on side lights the headlamps are on too although there is no extra lamp in the bowl ???? Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted September 24, 2010 Share Posted September 24, 2010 Dim dip I assume. Cheers Peter Quote Link to comment Share on other sites More sharing options...
ibexman Posted September 24, 2010 Author Share Posted September 24, 2010 no on with sidelights Quote Link to comment Share on other sites More sharing options...
crwoody Posted September 24, 2010 Share Posted September 24, 2010 As Peter says - "Dim Dip" - the dipped beam filament of the headlight is fed with a reduced voltage, (via a resistor) when the sidelights and ignition are switched on together. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 24, 2010 Share Posted September 24, 2010 It's a three-stage system for the headlamp. Dim - On but dimmed, with sidelights Dip - On (nearly) full power, but dipped down and to the left Full - On full power straight ahead. 200Tdi are fitted with it, at least mine is Quote Link to comment Share on other sites More sharing options...
western Posted September 25, 2010 Share Posted September 25, 2010 some of the last TD's in CSW trim had it too, no longer a legal requirement for UK. Quote Link to comment Share on other sites More sharing options...
Gromit Posted October 5, 2010 Share Posted October 5, 2010 My headlamps have only a normal 3 spade plug but when u switch on side lights the headlamps are on too although there is no extra lamp in the bowl ???? As said, it's dim dip on he TD5. Controlled by a pink relay behind the dash.You can remove it and (apparently, I haven't yet done so, but it looks right from the wiring diagram) short pins 2 and 8. Quote Link to comment Share on other sites More sharing options...
