mad_pete Posted September 25, 2010 Share Posted September 25, 2010 How wide is wide enough ? Snorkels seem to come in 2.5 , 3.0, 3.5 and Nigel massive. I have a 2.5" Southdowns snorkel but now I've up'd from a 3.5 to a 4.2 is that enough ? The manifold aperture is 70mm but throttle response seems slower with the snorkel connected. Is it going to be worth upping the diameter from the air filter to top to 3" ? Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted September 25, 2010 Share Posted September 25, 2010 When Sir Les of Hensonshire made mine, I decided not to go any smaller than the plenum inlet.... With bends / obstructions you ought to consider a slighty larger inner dimension. I decided similar to the plenum was good for me as I rarely run for any length of time at hi revs /WOT when most air will be needed... If you feel you engine is restricted, got up to 3 inches and see if you can feel the difference.. (oooerr Missus..!!) Neil Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 25, 2010 Share Posted September 25, 2010 Yes 3" will improve things. When I did mine speaking to JED for something as long as a snaorkel for bigger bore engines he didn'tr recomend them, if you "Have to have one" circa 80-95mm Hence mine As and when the 5.2 gets in there, I will prob run with snorkel disconnected and them just pop a pipe on when required Nige Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 25, 2010 Share Posted September 25, 2010 Same as the intake is safest. Smooth bends will have little effect anyway. Les. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 27, 2010 Share Posted September 27, 2010 I'm a lazy get, mine is 2.5" on the 4.6. Quote Link to comment Share on other sites More sharing options...
