Phillis Posted September 26, 2010 Share Posted September 26, 2010 ok i was silly and didnt change any of the seals,, (trying to save some pennies) what part numbers do i need for the seal behind the flywheel as its leaking from the base of the flywheel housing cheers edit: also could it be the seal that goes to the engine block? Quote Link to comment Share on other sites More sharing options...
western Posted September 26, 2010 Share Posted September 26, 2010 crankshaft rear oil seal, see page 209, item 18 here Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 27, 2010 Share Posted September 27, 2010 Conversion meaning Disco 200?? I common problem if the disco flywheel housing is used is that some bolts along the bottom of the housing are not used - meaning the engine gear box "couple" flex and as there are no bolts fixing the flywheel housing to the bottom of the engine, it opens up the rear end gasket and makes is leak, you need to put these bolts back in to solve any long term oil leak from this area, its not an easy job to do but I've got one bolt in so far out of 4. They're M10's that are straight through with a thread on the engine block side. Putting these bolts in help to keep the lower part of the gearbox and flywheel housing against the engine block thus stopping leaks. Quote Link to comment Share on other sites More sharing options...
Phillis Posted September 27, 2010 Author Share Posted September 27, 2010 No i used turbo diesel flywheel, i hope its the seal beheind the flywheel, what can you put on the seal so it wont come loose? cheers Quote Link to comment Share on other sites More sharing options...
western Posted September 27, 2010 Share Posted September 27, 2010 use a genuine LR seal & it should stay in place & last for years. Quote Link to comment Share on other sites More sharing options...
Phillis Posted October 3, 2010 Author Share Posted October 3, 2010 ERR1535 SEAL OIL ERR1440 GASKET FLYWHEEL TO BLOCK both genuine, britcar is £45 including postage any where cheaper? Quote Link to comment Share on other sites More sharing options...
Briarston Posted October 3, 2010 Share Posted October 3, 2010 No i used turbo diesel flywheel, i hope its the seal beheind the flywheel, what can you put on the seal so it wont come loose? cheers I don't think the TD flywheel housing bolts into the ladder frame of the 200Tdi engine, as does the original fitting. It's only necessary to counterbore the holes and fit socket head bolts a little shorter than the originals which pass through the g/box flange and flywheel housing. It's an easy job to to relocate the studs which need to be moved. The holes are already there, just tap them. I'm assuming it's a Disco engine you fitted. Quote Link to comment Share on other sites More sharing options...
