Finn Posted September 28, 2010 Share Posted September 28, 2010 Hi guys, I obtained several gearboxes at withams.. without knowing for what vehicle they are :-) I hoped to get some info by checking the numbers, but I have never seen these before: frc2855ca+19311 Any ideas? Ex Mod V8 maybe? Cheers, Finn Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted September 28, 2010 Share Posted September 28, 2010 looks like 4 speed rangie box's, OR 101 box's Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 28, 2010 Share Posted September 28, 2010 I don't mean to pry, but do you usually buy gearbox's you don't have a clue of what they are? Quote Link to comment Share on other sites More sharing options...
steve b Posted September 28, 2010 Share Posted September 28, 2010 They are RRC 4 sp/early 110 V8 I reckon , the 101 has a short bellhousing iirc hth Steveb Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 28, 2010 Share Posted September 28, 2010 that would make them LT95s . Quote Link to comment Share on other sites More sharing options...
Finn Posted September 28, 2010 Author Share Posted September 28, 2010 LT95 ..thanks! They are so nice and shiny, I just had to buy them Quote Link to comment Share on other sites More sharing options...
Finn Posted September 28, 2010 Author Share Posted September 28, 2010 has anyone seen this serial number before? FRC2855CA is stamped on each gearbox and on one of the transfer cases is this number: 19311 As far as I know does the LT95 serial number start with 13C........ and not like the number above. Cheers, Finn Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted September 28, 2010 Share Posted September 28, 2010 Certainly looks like an LT95..... Quote Link to comment Share on other sites More sharing options...
ChrisM_110 Posted September 28, 2010 Share Posted September 28, 2010 I've seen an LT95 12C on a 110 with a Salisbury front axle and a 17C on summat else. My Google fu is poor, there's no other help on the interwebs. Quote Link to comment Share on other sites More sharing options...
steve b Posted September 28, 2010 Share Posted September 28, 2010 You could try the Ashcroft team tomorrow , they may have a x-ref? cheers Steveb Quote Link to comment Share on other sites More sharing options...
Finn Posted September 28, 2010 Author Share Posted September 28, 2010 I will do that.. great tip. Cheers, Finn Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted September 29, 2010 Share Posted September 29, 2010 there were some light armoured 110,s in northen ireland,had salisburys on the front and rear with a v8 engine,probably used the gearbox you have,they were all disposed of about 5 years ago. Quote Link to comment Share on other sites More sharing options...
Finn Posted September 29, 2010 Author Share Posted September 29, 2010 Dave thinks it is an military 110 v8 lt95. Cheers, Finn Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted September 29, 2010 Share Posted September 29, 2010 Yes, the 110 had a bigger handbrake drum which yours seem to have. They also have the lowest transfer box ratio, perfect for racing. Quote Link to comment Share on other sites More sharing options...
jad Posted September 29, 2010 Share Posted September 29, 2010 Just wanted to say PM me with a price if you are thinking of getting rid of any. thats if they are for a V8 defender. cheers Jad Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted September 29, 2010 Share Posted September 29, 2010 Yes, the 110 had a bigger handbrake drum which yours seem to have. They also have the lowest transfer box ratio, perfect for racing. Is that as low as the 101 transfer box then? Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted September 29, 2010 Share Posted September 29, 2010 Yes, significantly. The 101 is 1.17:1 and the 110 was 1.34:1. The RR was 1.11:1 Quote Link to comment Share on other sites More sharing options...
berti1554 Posted October 1, 2010 Share Posted October 1, 2010 Yes, the 110 had a bigger handbrake drum which yours seem to have. They also have the lowest transfer box ratio, perfect for racing. Are you sure about that? I always thought they had the highest transfer box ratio. Was this on 4-cyl trucks only? Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted October 1, 2010 Share Posted October 1, 2010 Sorry, to clarify, the 110 ratio will give you the lowest top speed. Quote Link to comment Share on other sites More sharing options...
Finn Posted October 13, 2010 Author Share Posted October 13, 2010 guys, does this fit an '83 109 V8 as well? Cheers, Finn Quote Link to comment Share on other sites More sharing options...
Finn Posted October 22, 2010 Author Share Posted October 22, 2010 I finally got the time to check it's correct number. It's 17C00069A According to my sources an LT95 from the shorland armoured landrovers. Cheers, Finn Quote Link to comment Share on other sites More sharing options...
