series3100 Posted October 1, 2010 Share Posted October 1, 2010 On a 200tdi if i no longer have a standard airbox where should i put the crankcase breather pipe to? I'v just left it open to atmosphere but i got thinking and thought there must be a better option? Cheers, Brian Quote Link to comment Share on other sites More sharing options...
Marco Posted October 1, 2010 Share Posted October 1, 2010 On a 200tdi if i no longer have a standard airbox where should i put the crankcase breather pipe to? I'v just left it open to atmosphere but i got thinking and thought there must be a better option? Cheers, Brian I suggest into any hose / pipe before the turbo? Where did your air filter assembly go? Cheers Marco Quote Link to comment Share on other sites More sharing options...
series3100 Posted October 1, 2010 Author Share Posted October 1, 2010 I suggest into any hose / pipe before the turbo? Where did your air filter assembly go? Cheers Marco It's got one of those cone filter things on... Cheers, Brian Quote Link to comment Share on other sites More sharing options...
Marco Posted October 1, 2010 Share Posted October 1, 2010 It's got one of those cone filter things on... Cheers, Brian Like a K&N? On my Series I did route a crankcase breather hose into a K&N by drilling a hole in the metal top cover + fitted a connector for a hose. Maybe such a solution can work for you? Alternatively you can route the pipe into e.g. the chassis / atmosphere (previously used method on my Turbo Diesel) but that will be bit messy. Cheers Marco Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 1, 2010 Share Posted October 1, 2010 The whole purpose is to burn off the oil mist/vapour coming out, so you don't contaminate the roads etc. you could put another small filter on the end of your breather, but you'll just have to keep an eye on it for blocking up. Quote Link to comment Share on other sites More sharing options...
