tweetyduck Posted October 1, 2010 Share Posted October 1, 2010 I've gone a bought a full bull bar and winch. I currently have Genuine 110 STD yellow/yellow springs on the front. It should be Yellow/Yellow and a White/White but theres hardly any difference. I have Genuine 110 HD Red/Greens on the back, again as a pair and not with the Red/Red on the other side. Whats the recommened change for a winch on the front and combine this with a large bull bar? Should i go up to HD Fronts i.e. Yellow/White ? I'm not now mounting my wheel on the bonnet as this will go on the roof so i don't have even more weight on there. Any advice on this and fitting the winch will be greatfully received. Thanks Neill Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 1, 2010 Share Posted October 1, 2010 How massive is the climbing frame and winch combo you've bought? Have you weighed it? Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted October 1, 2010 Author Share Posted October 1, 2010 no but i can tommorrow. I got the Douglass Motors one and a Superwinch EP9 but am swapping to a Marlow Rope. edit. i note the measured front spring strength off that spring table is only 10kg different between STD and HD.. ?? http://members.shaw....springinfo.html Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted October 1, 2010 Author Share Posted October 1, 2010 like this. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted October 1, 2010 Share Posted October 1, 2010 The OE springs are progressive, with a low rate to begin with, then climbing to 210lb/in as the springs compress. The HD ones are a linear rate of 225lb/inch, so while the final rate isnt much different, they wont compress as much as they dont have the softer bit in them, but as a result the ride will likely become quite a bit stiffer. The 110 HD fronts are just 90 rear springs, so they're probably quite easy to find a set and try them out. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted October 1, 2010 Share Posted October 1, 2010 You will definately need to change the springs to maintain a decent ride height. Before I had my lift I added a modest bumper and a lowline winch and the front end dropped by around 1 inch. What do you use the car for? Do you have a need in the future for a lift? Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted October 1, 2010 Author Share Posted October 1, 2010 no need for a lift. Its off round the world (if its ever ready). So its manly on road in the UK and will be on road most of its life. Although a lot of the roads won't be up to much in some of the places we are going. The bars are purely to give front protection for various countries where animals roam free. Quote Link to comment Share on other sites More sharing options...
outdoor_ian Posted October 1, 2010 Share Posted October 1, 2010 I was in my local high street and saw plenty of moose roaming free over here !!!! Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted October 1, 2010 Share Posted October 1, 2010 I was in my local high street and saw plenty of moose roaming free over here !!!! Some of those must of migrated up this way !!! (I'll get my coat) John Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted December 4, 2012 Share Posted December 4, 2012 Ok so rather than write a new thread I thought I’d resurrect this old one as my query is similar. Am just about to bolt my (nearly) refurbed front axle to the chassis, and realised the original springs are a) quite flaky, probably the original ones and therefore 20yrs old so likely to have sagged b) possibly not up to the task of supporting the weight of my winch and bumper combo. This has yet to be purchased, but it will be more of an ‘insurance policy’ winch than a competition-warn-double-motor-Giggle-name-thing, after all I am driving a 110! In other words we’re looking at a Goodwinch or an Ebay special, which lists its mass as 43 kg. Factor in the bumper and moose-bar – which I probably will fabricate myself, but lets be generous and assume 20 kg – so 63 kg extra noseweight (assuming the factory fit girder weighs nothing – which by Land Rover standards, it does!). So what springs to fit? At the back I’ve put in the later CSW progressive springs (RKB101111). 110 Heavy Duty? (NRC9448 Driver, NRC9449 Passenger) Any other suggestions, based on experience? Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted December 4, 2012 Author Share Posted December 4, 2012 I fitted the standard HD spring setup as per the manual. The 90 rears on the front and the 130 with helpers on the rear. Its very stiff at the front even with the bar and winch. Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted December 5, 2012 Share Posted December 5, 2012 Hello Tweety! That's what I was thinking, was just curious if there were any alternatives. Am not planning a round-the-world-trip yet, but nevertheless don't fancy a stiff harsh ride up front, hence the question to the great and the good on here... Quote Link to comment Share on other sites More sharing options...
pat_pending Posted December 5, 2012 Share Posted December 5, 2012 I've got 90 rear springs on the front of my 110 sw utility, I certainly wouldn't call the ride stiff. If anything it's only slightly firmer than with the old ones. Tubular bumper with a Warn xd, steering guard and a hefty roof rack, with late csw springs on the rear, handling is spot on, just need some better dampers. Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted December 7, 2012 Share Posted December 7, 2012 Thanks Pat_pending, sounds like the setup I'll go for then! Will report back, though it might be a while... Quote Link to comment Share on other sites More sharing options...
farmerboy_y2k Posted December 8, 2012 Share Posted December 8, 2012 My 110 was factory fitted with PTO winch and HD front springs, mine are probably a litle tired now. But I wouldn't say the ride was much if any worse than std and better than most aftermarket "HD" springs. Atriculates pretty well as well. Quote Link to comment Share on other sites More sharing options...
Sirocco Posted December 8, 2012 Share Posted December 8, 2012 Go with HDs up front Matt. For comparison, ARB list their bumper at IIRC 30-35kg and Warn list an M8000 at IIRC 30kg. I would imagine a home made bumper to be in the same region and I think it would be silly to go foe anything other than HD springs on the front G Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted December 12, 2012 Share Posted December 12, 2012 Thanks Gareth, will put an order in after pay day!! Much as I'd love a bumper like yours I doubt I'll pick one up for sensible money, so home fab it is!! Quote Link to comment Share on other sites More sharing options...
Blackfiesta123 Posted December 13, 2012 Share Posted December 13, 2012 When i rebuilt my 90 i bought 4 rear springs. I have a very heavy winch bumper. To heavy really. But this made a world of difference so go for it. It also makes the ride feel much better. Tho my 20 year old springs were properly cream crackered and when used to brake hard the tyres would touch the wing archs. Quote Link to comment Share on other sites More sharing options...
