am i going to die?
ELVIS
yes, you are at some stage, sorry.
In the light of this, may I suggest that in addition to not wearing a spandex one piece suit you may also want to avoid wearing lycra cycling shorts for the same reason, unless of course you are a notorious homosexual, when the above is apparently perfectly acceptable :D
Mo :)
probably not :blink::hysterical: make sure your harness is as tight as possible, keep your hands/arms well inside the vehicle, do not hold onto the rollcage use the handgrip that should be in front of you, have a great event & tell us about the experience when you get back. :i-m_so_happy:
