Chris x Posted October 8, 2010 Share Posted October 8, 2010 Hi Guys, Im currently doing a 200 TDi conversion on my petrol Series 3. I have read thorugh the guide but cant determine wheither I need a petrol clutch or the diesel clutch to attach onto my TDi engine? My series 3 was originally a 2.25petrol. So I dont know wheither thats ok to use again or if I have to buy a series 3 diesel clutch? I will be re-newing no matter what, but I dont know what one to order. Any prefrences to what make would be best, or if I need to get an uprated clutch? Or is a bog standard clutch ok? It wont start slipping e.t.c. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 9, 2010 Share Posted October 9, 2010 You need the clutch plate to fit your gearbox - splines are the same for both petro; and diesel. Thrust bearing is the series type as well. Clutch cover is the TDI one (if it's different from the series one). This is assuming that you are using the series bellhousing. Les. Quote Link to comment Share on other sites More sharing options...
Chris x Posted October 11, 2010 Author Share Posted October 11, 2010 Perfect, thanks for that! Clutch is ordered and should be here on Wednesday, so hopefully I can then drop the lump in! Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 11, 2010 Share Posted October 11, 2010 Put in a new spigot bush for the crank shaft, too - if the original is worn, the primary pinion will be able to wobble, causing some movement in the main shaft too, which can cause the gears to jump out of selection (especially on the over-run). They cost virtually nothing, so it's definitely worth the effort. Quote Link to comment Share on other sites More sharing options...
Chris x Posted October 11, 2010 Author Share Posted October 11, 2010 Put in a new spigot bush for the crank shaft, too - if the original is worn, the primary pinion will be able to wobble, causing some movement in the main shaft too, which can cause the gears to jump out of selection (especially on the over-run). They cost virtually nothing, so it's definitely worth the effort. Would I need a TDi or a Series 3 spigot bush? Im fitting a Disco 200 TDi to a Petrol series 3 box if that makes a difference. Im guessing there easy to come by? Thanks for the suggestion! Well worth replacing bits whilst its all apart! Quote Link to comment Share on other sites More sharing options...
Chris x Posted October 11, 2010 Author Share Posted October 11, 2010 Seems as if my local Land Rover place have let me down as they can only get britpart series cluctch, which im not interested with, expecially with the TDi engine. Can anyone recommend a decent quality clutch to go with my TDi engine? Not to bothered on the price. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted October 11, 2010 Share Posted October 11, 2010 Seems as if my local Land Rover place have let me down as they can only get britpart series cluctch, which im not interested with, expecially with the TDi engine. Can anyone recommend a decent quality clutch to go with my TDi engine? Not to bothered on the price. Genuine? Already out the door. Quote Link to comment Share on other sites More sharing options...
Chris x Posted October 11, 2010 Author Share Posted October 11, 2010 Guessing there pricey? Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 11, 2010 Share Posted October 11, 2010 Delphi or Borg & Beck clutch plates will be fine. The spigot bush on the Tdi is the same as on the SII/SIII. Quote Link to comment Share on other sites More sharing options...
difflock Posted October 11, 2010 Share Posted October 11, 2010 Paddocks sell a AP (Borg And Beck) clutch plate for £30 + VAT... If that helps.... Quote Link to comment Share on other sites More sharing options...
Chris x Posted October 19, 2010 Author Share Posted October 19, 2010 Thanks! Just getting round to ordering this now! Is it a 9inch or 9.5inch I would need? Im looking here! : http://www.mm-4x4.com/land-rover-series-2-2a-3---gearbox--transmission-56-c.asp Thanks! Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 19, 2010 Share Posted October 19, 2010 9.5 Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 19, 2010 Share Posted October 19, 2010 http://www.mm-4x4.com/series-22a3-clutch-plate-95inch-borg-and-beck-232-p.asp Quote Link to comment Share on other sites More sharing options...
