series3100 Posted October 13, 2010 Share Posted October 13, 2010 Hi, Can someone tell me the distance between the 2 fearlead mounting bolts (centre to centre)? I assume this is a standard measurment... Thanks very much, Brian Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 15, 2010 Share Posted October 15, 2010 No it isn't - it depends on which winch you have and some winches have four bolts not two In addition to that some winches have the bolt holes aligned with the slot for the winch rope, and some have them offset to one side (Milemarker is like this for example). There are only 3 or 4 common ones but need to know which winch. Quote Link to comment Share on other sites More sharing options...
series3100 Posted October 15, 2010 Author Share Posted October 15, 2010 No it isn't - it depends on which winch you have and some winches have four bolts not two In addition to that some winches have the bolt holes aligned with the slot for the winch rope, and some have them offset to one side (Milemarker is like this for example). There are only 3 or 4 common ones but need to know which winch. oh i see... Reason i ask is because i'm making a rear crossmember with winch mount for my DT project but don't have actually have a winch... it's just for a project + i need a new rear crossmember if you see what i'm getting at Thanks for the info, Brian Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 16, 2010 Share Posted October 16, 2010 OK in that case choose one that fits a common type of winch, make it to suit that and flog it on Ebay afterwards Quote Link to comment Share on other sites More sharing options...
