Russell_ds80 Posted October 18, 2010 Share Posted October 18, 2010 hi all. im looking for a winch and not sure what to go for. i want to do the odd winch challenge but nothing crazy. yet! so im looking for something thats not too expensive but want something half decent. any ideas?? cheers Russell Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 18, 2010 Share Posted October 18, 2010 Goodwinch TDS. Cheap, well made and will pull a house down. Quote Link to comment Share on other sites More sharing options...
trt1617 Posted October 18, 2010 Share Posted October 18, 2010 this is the thing im going through at the moment and it seems you either go second hand warn that you cant know how its been treated or for the same sort of money a brand new goodwinch tds one with warranty and its new or for a bit more one with a bowmotor 2 large drum and 125feet of rope! seems silly thinking about it. but looking at all the pics and vids of events they all have warn 8274s with twin motor top houseings and stuff is a lowline winch such as the tds competative out in events? against the warn? Quote Link to comment Share on other sites More sharing options...
robhybrid Posted October 18, 2010 Share Posted October 18, 2010 if you add the dave bowyer free spool device(so you only pull out what you need) I guess the pull speed under load isn't too far off warn. Jim(gigglepin) has done/been involved with speed improvements with low line winches though. The low line winch is a way of getting into it without spending silly money and if you decide to go further the low line is a good rear or center winch once you have a fancy one up front. in my opinion the low line winch is more suited to being left on the front of a vehicle for long periods without use than the 8274. I have bought loads of second hand 8274 winches ever and as long as you take into account that you are almost bound to have to purchase a new motor, albright and possibly brakes the rest is reasonably strong. Jim stocks re-build kits of various descriptions so repair is almost always possible. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 18, 2010 Share Posted October 18, 2010 but looking at all the pics and vids of events they all have warn 8274s with twin motor top houseings and stuff That's because a lot of challenge events seem to be more about who has the most bling kit than about what works. I've seen and heard of people using TDS winches with success in challenge events, although I think it depends on the event. If it's designed to literally be a case of drive up, hook up line, winch up vertical hill, get punch, winch back down, and repeat, then an 8274-derived multi £thousands's monster will come out on top. If however it's been designed well and actually involves some skill in driving, navigation and rigging, then any decent winch worth it's salt will be competitive. Quote Link to comment Share on other sites More sharing options...
MrHT Posted October 18, 2010 Share Posted October 18, 2010 tds is excellent especially if you fit the free spool. And if it's one thing i've learnt recentally, the quicker you get the rope out the better. a friend of mine has a tds on the back (with davids free spool) and a twin 8274 on the front (no free spool. i'd sooner take him backward through a section as it's so much quicker Before I compete again i will be invsting in a free spool as in most place's this is the difference now between being competetive and not. Quote Link to comment Share on other sites More sharing options...
moose Posted October 19, 2010 Share Posted October 19, 2010 The other thing to think about its that with a motor over drum winch (like an 8274) is that they can hold more rope and you dont have to worry about it bunching up and braking the tie bars. But my view is a "normal" 8274 under heavy load (ie 2 tonne truck through a bog) will be about as fast as a tds under the same heavy load, and now days with an extra big drum on a tds you can hold the same amount of rope as a standard 8274... Quote Link to comment Share on other sites More sharing options...
Boothy Posted October 19, 2010 Share Posted October 19, 2010 8274 all day every day Brilliant brake Availabilty of mods to suit all occasations and needs Ease of repair in the field Every nut bolt washer, bearing and bush is easily and readily available Speed, reliability, adapability, I run 125ft of 12mm Marlow comp rope without any worries of bunching, could easily go up to 150ft if rope was cheaper...... That lovely clicking noise on recall tells me whats going on.......... think about it...... Bling does not even come in to it but brains do Quote Link to comment Share on other sites More sharing options...
Joe 90 Posted October 19, 2010 Share Posted October 19, 2010 we run a 8274 on the front tds on the rear. the tds is so slow compared to the 8274 if we could afford to we would be puting a 8274 on the rear and before you say it yes the tds has air freespool O and the grub screew that holds the rope is hopeles had to weld a bar on the drum to hold the rope in the end as it let us down to many times Quote Link to comment Share on other sites More sharing options...
MrHT Posted October 19, 2010 Share Posted October 19, 2010 8274 all day every day Brilliant brake Availabilty of mods to suit all occasations and needs Ease of repair in the field Every nut bolt washer, bearing and bush is easily and readily available Speed, reliability, adapability, I run 125ft of 12mm Marlow comp rope without any worries of bunching, could easily go up to 150ft if rope was cheaper...... That lovely clicking noise on recall tells me whats going on.......... think about it...... Bling does not even come in to it but brains do don't get me wrong boothy I agree entierly, thats why I'm runnning 8274 front and back. But i've also come to realise not many people can find them at dirt cheap prices Quote Link to comment Share on other sites More sharing options...
yella 90 Posted October 19, 2010 Share Posted October 19, 2010 don't get me wrong boothy I agree entierly, thats why I'm runnning 8274 front and back. But i've also come to realise not many people can find them at dirt cheap prices I manage to drop on a few on the cheap quite often, just have to be in the right place at the right time as they say. Also the spare cash nocking around which i understand some people do. On another note the tds is a cracking bit of kit and the freespool actually works unlike most 8274's Quote Link to comment Share on other sites More sharing options...
Boothy Posted October 19, 2010 Share Posted October 19, 2010 But on the "throwing good money away theme" how many clouds of smoke have you seen at events and playdays from these BARGAIN Chinese imports at £300+ going up in a puff of smoke, no spares available, guarantee not worth the paper it's written on ,"chuck it in the skip mate, and put it down to experience", for not much more and a bit of quality time spent waiting to pounce as Dan says on a cheap Warn 8274 because they do come up every now and then and are well worth the wait and money. Take into account comp entry fee's and costs of travelling etc thrown away on a cheap winch because it fails early in the day, and could leave you in a awkward spot, then perhaps common sense says wait until your properlly equipped, and no I don't have a bad word to say about TDS/Goldfish winches belting bit of kit, just not my choice, both my 8274's were second hand re-serviced models. I sometimes feel a bit gutted for folks when these cheapo winches let go after a very minimum work out, nobody likes to see a blokes money thrown away, so best advice is scan the ads and save up Pal, but go for a branded winch with full spares and a reputation, choice is yours...... Quote Link to comment Share on other sites More sharing options...
Russell_ds80 Posted October 19, 2010 Author Share Posted October 19, 2010 thanks for all the advice. i think im going to get a tds for now then move it to the back once ive saved the pennies and bought a 8274. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 20, 2010 Share Posted October 20, 2010 Given that the OP doesn't have much money to spend and is just starting out I think there is a lot of merit in the earlier suggestion of getting a lowline winch that can subsequently be moved further back in the truck if and when the challenge bug bites has a lot of merit. A TDS would be my choice and you can add free spool and over volting as and when funds permit. Boothy - the number of 8274 problems at challenges greatly exceeds the number of TDS problems in my experience. Having said that, there are of course a lot more 8274's there in the first place so not exactly a catagoric statement! Just wanted to make it clear that 8274's are not invincible. Quote Link to comment Share on other sites More sharing options...
Orange Posted October 20, 2010 Share Posted October 20, 2010 Just to throw another one into the mix... I have run my EP9 as a front and centre winch. It has never let me down and barring a couple of cleaning and regreasing sessions, it has needed no maintenance whatsoever. My TDS (previously on the front and now on the rear) has burnt out a motor and suffers from rope slip due to the grub screw being useless. I have very little confidence in it at the moment! So much so, that I am seriously considering putting the EP9 in it's place in the short term and modding the crossmember to accept an 8274 in the longer term. The 8274 on the front was standard (apart from the mainshaft and a +3" drum) last year and served us well. Now has twin-motor and Delta-Tek air freespool and still owes me significantly less than a standard 8274 would cost to buy new. Bargains are out there... Just last week, an 8274 on ebay finished without any bids starting at 99p, so it's just a case of watching and waiting... Start saving now and by the time the next season of competing starts, you will have found one. Quote Link to comment Share on other sites More sharing options...
Boothy Posted October 20, 2010 Share Posted October 20, 2010 Hey Bishbosh, I totally agree with you that 8274's are not bullet proof nor anywhere near it, but they can over a period of time be made a lot stronger and IF treated with respect perform quite well in standard form. But the beauty of is them is chances are that most can be fixed at a comp and somebody somewhere will have the part you need. My good mate John Sales (Saley) makes the best winch I have come across for speed/strength/ cost, but I'm not a lover of hydraulic systems hence I use a pair of 8274's c/w with mainshaft mods. I said earlier the TDS is a belting piece of kit just not my choice. Boxers or Y-fronts ? Blondes or Brunettes ? Boggers or Simex ? McDonalds or Burger King ? Half full or half empty ? :rolleyes: :rolleyes: :rolleyes: Quote Link to comment Share on other sites More sharing options...
trt1617 Posted October 20, 2010 Share Posted October 20, 2010 ok so a few of you use the warn 8274 or sound like you have brought them second hand. what are the main things to check on a used one as in not to give top dollar for something thats gonna need a total rebuild costing loads? some iv seen have no solenoids or wireing. so any thing to check any pointers? have heard tings about the freespool lever bings a bit weak i think but any pointers would be apreciated can they die from just laying around in a shed somwhere? many thanks Quote Link to comment Share on other sites More sharing options...
chris-b Posted October 20, 2010 Share Posted October 20, 2010 I agree with chris on this and have myself learnt the hard way, 9 times out of 10 cheapest is usualy the most expensive in this game.By a cheap winch with the brake in the drum and melt a rope on a long drop and your half way to an 8274 if your still in one piece.Chris tell em how much rope you carry on the rear winch, hardly worth having one :lol: But on the "throwing good money away theme" how many clouds of smoke have you seen at events and playdays from these BARGAIN Chinese imports at £300+ going up in a puff of smoke, no spares available, guarantee not worth the paper it's written on ,"chuck it in the skip mate, and put it down to experience", for not much more and a bit of quality time spent waiting to pounce as Dan says on a cheap Warn 8274 because they do come up every now and then and are well worth the wait and money. Take into account comp entry fee's and costs of travelling etc thrown away on a cheap winch because it fails early in the day, and could leave you in a awkward spot, then perhaps common sense says wait until your properlly equipped, and no I don't have a bad word to say about TDS/Goldfish winches belting bit of kit, just not my choice, both my 8274's were second hand re-serviced models. I sometimes feel a bit gutted for folks when these cheapo winches let go after a very minimum work out, nobody likes to see a blokes money thrown away, so best advice is scan the ads and save up Pal, but go for a branded winch with full spares and a reputation, choice is yours...... Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted October 20, 2010 Share Posted October 20, 2010 ok so a few of you use the warn 8274 or sound like you have brought them second hand. what are the main things to check on a used one as in not to give top dollar for something thats gonna need a total rebuild costing loads? some iv seen have no solenoids or wireing. so any thing to check any pointers? have heard tings about the freespool lever bings a bit weak i think but any pointers would be apreciated can they die from just laying around in a shed somwhere? many thanks I wouldn't worry about no wireing or solenoids as you will want an albright anyway, and the wiring wont be made to suit you or your vehicle. but 100quid max spent on electrics. You will more than likely need a new motor - 300quid for a good one. The rest of it, well check the 8274 casing for cracks etc, whip the top casing off the winch (3 allen bolts) and look for stripped teeth on the gears. Dont let it hold you back tho, EVERYTHING can be replaced and generally improved and you can end up with a much improved 8274 for less money than a new one. I currently have a 1980ish 8274 which i have rebuilt top to bottom for about ~200quid, its now slightly uprated over a standard winch and stands me at about 800quid. Im looking out for a bow2 motor now to give it some balls Quote Link to comment Share on other sites More sharing options...
MrHT Posted October 20, 2010 Share Posted October 20, 2010 best thing i ever did is waiting for an 8274. Mine is standard apart from a bow2, gwyn brake pack and albright and stands me about 450 500 so far. Quote Link to comment Share on other sites More sharing options...
Russell_ds80 Posted October 20, 2010 Author Share Posted October 20, 2010 hhhmmmm. well im in no rush so might just save and wait for an 8274 to come up. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted October 21, 2010 Share Posted October 21, 2010 I've got a nearly new 8274 with Xp motor, GP main shaft upgrade or summink Albright etc, really is over and above any winch I've had before Quote Link to comment Share on other sites More sharing options...
simonr Posted October 21, 2010 Share Posted October 21, 2010 Would a Delta-Tek style freespool for TDS's be worth developing? I figured out how it could work yesterday in a bit of a spark of inspiration! I have an 8274 which I'm very fond of - it's a fantastic winch. But I also have two TDS's and and EP9 on other vehicles because they are cheaper new than most used 8274's and you can have one delivered tomorrow without spending months scouring eBay. Si Quote Link to comment Share on other sites More sharing options...
Mark Posted October 21, 2010 Share Posted October 21, 2010 Yes Please Si! With the TDS freespool (air or lever operated), you still need to turn the gearbox when pulling the rope out. When you compare this to only turning the drum (as per the Delta-tek freespool) it makes a world of difference, particularly when you are struggling for grip anyway - We still often power out in preference to the freespool on the rear for that reason. Mark Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 21, 2010 Share Posted October 21, 2010 A combined twin motor and drum freespool end plate, sounds like a good product if it can be done for the right price The TDS freespool might be just one finger(apparently), but it is still a PITA to get it off the drum quickly, as with Mark I tend to just pay it out on the motor. Quote Link to comment Share on other sites More sharing options...
