how to change battery to an lucas 3txb keyfob?
hello!
My battery on 3TXB defender keyfob has (probably) run out of juice. Luckily otherone is still working!
Can i change the battery without a problem or do removal of the battery erase all data/kode/progaming my keyfob?
RAVE says that i have 5 min to change battery bfore immobiliser kicks in! Anobody have any 1st hand information?
cheers
Jan
ps: its an 110 300tdi -97my
Im guessing its the same as a td5.
You have 5 mins to do it from the start of the procedure so make sure you've got the battery and something to prise open the fob ready.
Unlock/disable alarm of vehicle.
Insert key, turn to position II then 0 and remove key.
Remove battery from fob, and press any of the buttons for 5 secs to drain any electrical energy.
Put in new battery and put fob back together.
Press padlock button 4 times next to vehicle to resynchronise then unlock button.
Sorted.
