Russell_ds80 Posted October 30, 2010 Share Posted October 30, 2010 on my 1989 90 the fuel light flashes if you brake hard or accelarate hard. the gauge reads around half and ive looked inside and its about half full. so why does it flash?? cheers Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2010 Share Posted October 30, 2010 due to the movement of the fuel & sender unit arm inside the tank, usually starts to flash with around 20 litres remaining, not much you can do about it, the tank does have internal baffles. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 30, 2010 Share Posted October 30, 2010 They must all do it. Mine does it ... a little bit annoying but nowt you can do AFAIF Quote Link to comment Share on other sites More sharing options...
Russell_ds80 Posted October 30, 2010 Author Share Posted October 30, 2010 i might disconnect it then because it gets on my nerves. am i right in saying that it will be one of the three wires on the top of the sender.?? Quote Link to comment Share on other sites More sharing options...
Unsworth Posted October 30, 2010 Share Posted October 30, 2010 Mine doesnt flash until there is like 10 litres in the tank? This is on a 1988 90 too! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 30, 2010 Share Posted October 30, 2010 Some pre-Td5 vehicles had a damping circuit fitted, my 200Tdi did. Was a little circuit board behind the dash, wrapped in a tape stuff. Td5 vehicles have a fuel gauge that is damped by the speedo head as the signal passes through it. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 30, 2010 Share Posted October 30, 2010 being an 84, I doubt mine has this Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2010 Share Posted October 30, 2010 Some pre-Td5 vehicles had a damping circuit fitted, my 200Tdi did. Was a little circuit board behind the dash, wrapped in a tape stuff. I'll see if it's shown on the wiring diagram. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 30, 2010 Share Posted October 30, 2010 I could never find any mention of it on any diagram I had. I was under the impression the standard setup was to take the low fuel light feed from the sender unit on the tank itself. That's what the diagrams all show. My sender unit only has two wires on it. Earth and the signal. The low fuel light terminal is unused, the power for that warning light instead being fed from this weird PCB in the dash. It comes from the Td5 speedo now. Next time I'm in the dash I'll fish it out and examine it more closely. Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2010 Share Posted October 30, 2010 I could never find any mention of it on any diagram I had. I was under the impression the standard setup was to take the low fuel light feed from the sender unit on the tank itself. That's what the diagrams all show. My sender unit only has two wires on it. Earth and the signal. The low fuel light terminal is unused, the power for that warning light instead being fed from this weird PCB in the dash. It comes from the Td5 speedo now. Next time I'm in the dash I'll fish it out and examine it more closely. the tank sender/low fuel level unit shown as item 74 on the wiring diagram below, item 85 is the fuel gauge. seems strange just to identify it as low fuel level unit & not as just fuel level sender Quote Link to comment Share on other sites More sharing options...
Russell_ds80 Posted October 30, 2010 Author Share Posted October 30, 2010 mine has 3 wires. ill have a look tomorrow see if i can figure it out. Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2010 Share Posted October 30, 2010 mine has 3 wires. ill have a look tomorrow see if i can figure it out. the 3 wires will be centre stud = earth whire/slate = low fuel light green/black = fuel contents gauge Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 19, 2018 Share Posted January 19, 2018 On 30/10/2010 at 10:15 PM, Retroanaconda said: I could never find any mention of it on any diagram I had. I was under the impression the standard setup was to take the low fuel light feed from the sender unit on the tank itself. That's what the diagrams all show. My sender unit only has two wires on it. Earth and the signal. The low fuel light terminal is unused, the power for that warning light instead being fed from this weird PCB in the dash. It comes from the Td5 speedo now. Next time I'm in the dash I'll fish it out and examine it more closely. Dis you ever work out what the wee pcb was? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 20, 2018 Share Posted January 20, 2018 1 hour ago, Maverik said: Dis you ever work out what the wee pcb was? These were used for the 200TDI era. They were part of the wiring harness and not a separate part. 300TDi era has no low fuel light.... The thread has a link for a nice aftermarket one. Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 20, 2018 Share Posted January 20, 2018 Nice one Red just ordered one of those modules from spiyda. Thanks Quote Link to comment Share on other sites More sharing options...
