defender puma engine fuel system bleed
hey all . im workin on a land rover defender puma engine. just changed the fuel filter. but now i need to bleed the fuel system that i thought would be like a td5 ingnition to number 2 and press pedal 10 times. but apparently thers a certain for doin the job just wondered if any one else has found other ways of doing it? any help would be much apprieciated
cheers
chris
Hi Chris,
You need a special bleeding tool:
Unfortunatly you can't use the same procedure as the TD5 as there is no electric fuel pump. (On the bright side there is no electric fuel pump to fail :) )
Have a look at this thread, there's heaps of info about the bleeding system:
http://www.defender2.net/forum/topic516.html?highlight=bleed
Cheers,
Tim
