geoffbeaumont Posted August 27, 2005 Share Posted August 27, 2005 I know the Haynes manual is notoriosly optimistic, but 'ease the fuel rail and injectors out and remove from the engine bay'... They've been there for twelve years and they're very comfortable where they are, thank you... Is there some trick to coaxing the little buggers out (Hotwire V8), because I'd very much like to get at my head gaskets sometime today?!! Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 27, 2005 Author Share Posted August 27, 2005 Answered that one for myself - lever them out with a spanner Random unrelated question: If you have an injected LPG kit, where do the injectors go? Do you have to change the intake manifold for one with two sets of injector ports? Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted August 27, 2005 Share Posted August 27, 2005 drill and tap existing. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 29, 2005 Share Posted August 29, 2005 While you're there you may as well do a 3rd set of holes for Nitrous Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 29, 2005 Share Posted August 29, 2005 Geoff, You must be doing a very detailed stripdown if you are taking the injectors out to replace the head gaskets Could you not have left them in and taken the whole inlet off in a "oner". (Apart from the plenum which needs to come off first) Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 29, 2005 Author Share Posted August 29, 2005 While you're there you may as well do a 3rd set of holes for Nitrous Now that really would upset the insurers Quote Link to comment Share on other sites More sharing options...
