ROGUE TROOPER Posted June 14, 2006 Share Posted June 14, 2006 Can someone tell me (or better still take photos) of the brackets that hold the belts. I need to convert mine to "BS" spec belts as at the moment they are "modified" Ford items and have to take them out every MOT!! Ta Quote Link to comment Share on other sites More sharing options...
minivin Posted June 14, 2006 Share Posted June 14, 2006 Can someone tell me (or better still take photos) of the brackets that hold the belts.I need to convert mine to "BS" spec belts as at the moment they are "modified" Ford items and have to take them out every MOT!! Ta Have a look at mine when I'm free next, I've got the plates on the drivers side for it Quote Link to comment Share on other sites More sharing options...
minivin Posted June 14, 2006 Share Posted June 14, 2006 Actually, here's the plate for mounting the inertia reel: The feeder loop then goes on top of the bulkhead as per my three point harness mount, down to the normal locking point by the driver and down to the door B pillar base. Craddocks were selling the kit on Ebay last week! worth giving them a shout Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 14, 2006 Share Posted June 14, 2006 You can fit any make of seat belt as long as it's securely fixed. On catflap I had the reel and the end anchored in the corner behind the seat, and then up to shouler height on the 'B' Pillar. The lock mechanism was attached to the crossmember under the rear bulkhead, and then up through the floor behind the seats. I made my own brackets by welding two pieces of 50mm angle iron together to form a 'T' shape, then 4 x m8 bolts through the bodywork and a spreader plate on the opposite side. Considering the standard item is 4 x 7/16" bolts, I would say the job I did was stronger. If you need those two brackets that are on top of the rear bulkhead Richard, let me know. Les. Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted June 14, 2006 Author Share Posted June 14, 2006 Thanks guys. I need two of these..... Where/what does the Inertia reel bolt to? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 14, 2006 Share Posted June 14, 2006 Inertia reel is the type of belt you are more familiar with - retracts when you release it. As opposed to webbing, which is a mess. Les. Quote Link to comment Share on other sites More sharing options...
minivin Posted June 14, 2006 Share Posted June 14, 2006 Where/what does the Inertia reel bolt to? as per me photo, it mounts to the square plate that is rivetted to the bulkhead, it sits between the bulkead and the drivers seat, sends the belt upto the first guide at the top of the bulkhead, and then over the seat top over the drivers shoulder Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted June 15, 2006 Author Share Posted June 15, 2006 I see now, thanks all, will go to the local LR bloke and see if I can get the lot from a S3. Ta Quote Link to comment Share on other sites More sharing options...
