Disty Posted November 14, 2010 Share Posted November 14, 2010 My 300tdi always squealed when you put revs on it, but when doing my rebuild I deliberately changed the fan belt to see if it would help. It didn't. So I then changed the bearing in the fan belt tensioner, which I thought would help. It didn't and it's possibly worse than before, but I can't really tell. What else could it be? It's ok when it idles but as soon as you start to put your foot down it really does squeal loudly!! Quote Link to comment Share on other sites More sharing options...
ashtray Posted November 14, 2010 Share Posted November 14, 2010 a leak in your turbo hoses can cause this, i doubt the intercooler will be leaking as they are solid ali but a hose can definately make this noise. a bit like slowly letting the air out of a balloon! Check all your hoses are tight and have no splits Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 14, 2010 Share Posted November 14, 2010 Turbo bearings on their way out? Check the oil feed to and from the turbo perhaps. Quote Link to comment Share on other sites More sharing options...
Disty Posted November 14, 2010 Author Share Posted November 14, 2010 Thanks, I'll check that- but I also swapped the old ones for silicon hoses so I'd be surprised if it was that. But it does make sense that if it were the turbo, it would only happen at higher revs! Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 14, 2010 Share Posted November 14, 2010 Hope its not, but they do squeal if oil starved or failing. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 14, 2010 Share Posted November 14, 2010 Alternator belt? My truck has always squeeled a bit... but yesterday it went mad and squeeled constantly when over about 1500rpm.... Turned out the Alt belt was shagged Quote Link to comment Share on other sites More sharing options...
Disty Posted November 14, 2010 Author Share Posted November 14, 2010 Eh oh better not be the turbo.. will check that out. I thought the alternator belt was part of the serpentine belt that does everything? Quote Link to comment Share on other sites More sharing options...
outdoor_ian Posted November 14, 2010 Share Posted November 14, 2010 ^^^^^^ It is on a 300TDI unless you are running a twin altenator set up. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 14, 2010 Share Posted November 14, 2010 Of course Sorry! Quote Link to comment Share on other sites More sharing options...
Disty Posted November 15, 2010 Author Share Posted November 15, 2010 Ok I've thought about this and it may well be the turbo. How do I check if the oiler is working properly? Quote Link to comment Share on other sites More sharing options...
western Posted November 15, 2010 Share Posted November 15, 2010 take the feed pipe off & get someone to crank the engine over, it's pressure fed from the main oil gallery/oil pump. Quote Link to comment Share on other sites More sharing options...
Woody3 Posted November 16, 2010 Share Posted November 16, 2010 IF it's not the turbo, have you tried the penny trick... http://www.landyzone.co.uk/lz/f7/300tdi-squealing-whining-noise-97819.html Quote Link to comment Share on other sites More sharing options...
Disty Posted November 16, 2010 Author Share Posted November 16, 2010 Wow, that looks amazing! Thanks! Off to work on the truck tonight so this will be the first thing I try! Quote Link to comment Share on other sites More sharing options...
