old leafer Posted November 14, 2010 Share Posted November 14, 2010 my mate has a prob with his td5 the heater it only blows cold its an es with the climet control there is plenty of coolent in it and the temp when running is normal has any one come across this prob before Quote Link to comment Share on other sites More sharing options...
dooroy Posted November 17, 2010 Share Posted November 17, 2010 I had a similar problem with mine last year and it was caused by low coolant level . And an airlock could also cause it - did he check if both heater pipes are getting hot ? There is a post somewhere that tells how the climate control can run a diagnostic on itself - if I find it I will post back and you can see if that shows up any problems . http-www.landyzone.co.uk-lz-f8-dis..cs-103487.html Quote Link to comment Share on other sites More sharing options...
