pinny Posted November 15, 2010 Share Posted November 15, 2010 today ive developed a problem the disco wont engage gears very well if i double the clutch its no problem clutch fluid is ok no leaks the clutch was changed about 4 months ago im looking into removing the damper to eliminate this can i just join the pipes toghether and bypass this completely any ideas ,chris. Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted November 15, 2010 Share Posted November 15, 2010 I bypassed it on my 200tdi without any problems, the pipe going into the damper is the same thread as the one on the slave so it's a straight forward job. Quote Link to comment Share on other sites More sharing options...
bear Posted November 16, 2010 Share Posted November 16, 2010 Hi, Double de-clutching takes the strian of the synchromesh gears hence easier gearchanging. Could this be the problem? ,although I wouldn't have thought it was on all gears. Regards Quote Link to comment Share on other sites More sharing options...
Wolfie69 Posted November 16, 2010 Share Posted November 16, 2010 I did the same on my 200tdi a few years ago it had the syptoms as you have described. I simply moved the pipe from the damper to the slave cylinder problem solved. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 16, 2010 Share Posted November 16, 2010 Damper also used on the Metro I beleive. I know people have problems bleeding them and they don't last forever. They are meant to stop vibrations through the fluid into the pedal. Quote Link to comment Share on other sites More sharing options...
pinny Posted November 16, 2010 Author Share Posted November 16, 2010 thanks for the relies all but im now thinking its the gbox or clutch breaking up going to strip it the weekend to investigate further Quote Link to comment Share on other sites More sharing options...
