Oil additives
Tonk
thinking about running oil additives in engine and g/box, who uses wot and do you know if its any good or just hoping? considering slick 50 or Activ 8 or wotever its called :unsure:
do they make things smoother or just there incase your lr developes a leak and runs low?
lr with an oil leak? never.......... :lol:
You might find this interesting:
http://www.carbibles.com/additives.html
Seems Slick50 and many others have lost a few lawsuits of late :huh:
There is a company in Fareham that makes the machinery that puts the additives into oils and fuels, I believe they supply the additives too. Can't remember the name but they're in the Wallington estate, might be worth searching them out and asking?
Active-8 I found very good but I can't work out if its better or not over time but I noticed it the moment I added it to the 4.2.
I used to run it in every thing but when I ran out I never got round to replacing it.....
I think its very good but far from cheap
i always see active-8 demonstrated at shows, sparking bearings etc, looks impressive, no idea on cost.
That was the one for me
It was seeing a chap I know from the CTOC that owns a lorry and Plant repair garage and site fitters spend £600 on buying Active-8 off the guy at one show :o .
that was a few years ago but my truck need very little maintenance from warn parts from when I started using it four years ago and I ran out two years ago
ISTR Dave Haynes muttering something when passing an Activ-8 stand at a show (they're the ones with the metal bar you can force into a metal wheel as a demo aren't they?) it was something technical that was beyond me, asking on the Shire e-group may get a response from him.
I think the gist of DH's comment was that the demonstration only shows one type of wear, which that additive does work for, but there are other things going on in an engine/gearbox that it potentially bu**ers up.
I'd say you're better off just putting better quality oil in rather than adding stuff afterwards - the oil companies' research budgets are astronomical so I'd hope they know what they're doing.
I did the bar pressing thing on the active-8 stand but am sceptical for the rreasons FF says; it is unlikley the bloke has discovered something magical; more likely the stuff is just better than other oils for the demonstration he uses; and the big oil companies would be selling the stuff.
I did used to add slik 50 to engine, gearbox etc; can;t say I notice any difference in the engines but gearbox on the bike did; bu**er so long ago, can;t remenber if it was for the best.... :huh:
I'd save just use a decent oil to the manufactureres spec.
Before I saw Slick50 in the UK
A product called Nulon (I think) was touted around by another company with the marketing that, they installed it in an engine (don’t know what sorry) ran it for the necessary period to spread evenly, and then let all the oil out of the sump as the engine continued to run. The spiel was how long the engine ran before/without failure.
In theory the product was proven, unfortunately Nulon (if it worked) disappeared and Slick50 stayed so I don’t know which was best.
I put Slick50 into my engine recently and now (unconnected?) it sounds like it’s run dry on start up (might be pres relief stuck).
Try this stuff:-
www.boronbond.co.uk
Works a treat in my G4 Disco.
Regards
Scrumps
