Tibout Posted November 28, 2010 Share Posted November 28, 2010 hi guys weather is getting cold and i've notice several of us are having issue starting the truck in the morning. my have the same issue as well. its a 200tdi 113k on the clock new battery etc. i suspect the heater plug to be faulty. i'm just wondering how hard is it to replace them. is there any thread which describe the procedure? thanks in advance thierry Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted November 29, 2010 Share Posted November 29, 2010 TBH this is dead easy - even I can do it and L'm no expert ! You'll need a decent socket set to unscrew the terminal wire connection ontop of the plug and then one for rmoving the plug itself. All 4 all are in a line - connected in series with a wire (usually yellow) - on the drivers side of the engine block just below each of the 4 injectors (they are the ones with all the pipe work lead to and from them). Simple to disconnect wire - remove heater plug carefully ensuring you dont break it. Repeat but in reverse for the fitting. Even if you are a little slow doing this for the first time - 5 minutes for each and you're done. HTH hi guys weather is getting cold and i've notice several of us are having issue starting the truck in the morning. my have the same issue as well. its a 200tdi 113k on the clock new battery etc. i suspect the heater plug to be faulty. i'm just wondering how hard is it to replace them. is there any thread which describe the procedure? thanks in advance thierry Quote Link to comment Share on other sites More sharing options...
Tibout Posted November 29, 2010 Author Share Posted November 29, 2010 Hi thanks very much for that I'm going to get that sorted today. Really appreciate your help king regards Quote Link to comment Share on other sites More sharing options...
Challo Posted November 29, 2010 Share Posted November 29, 2010 Just done mine this morning, took bout half an hour,(that includes time for re-warming fingers) and only £17 +VAT for a set! Not too bad. Quote Link to comment Share on other sites More sharing options...
Tibout Posted November 29, 2010 Author Share Posted November 29, 2010 where did you get them? and which brand are they? did you remove them when the engine was warm? thanks a mil Quote Link to comment Share on other sites More sharing options...
Challo Posted December 1, 2010 Share Posted December 1, 2010 I got them from Simon Services in Wakefield(Independant Land Rover Specialist) unfortunately they are Br£tpa%t but thats all he had available and i fitted them with engine cold as it was quicker to change 'em then start the landy as it flatted battery day before as wouldn't start til about 20mins of pre heating!!!! Hope this helps Cheers Chris Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted December 2, 2010 Share Posted December 2, 2010 Unfortunately the Br!tp@art (and other makes) don't last very long, 6 months is about average. The OEM Beru ones cost more but last for years. Quote Link to comment Share on other sites More sharing options...
