Tomas4x4 Posted November 30, 2010 Share Posted November 30, 2010 Hello all, Ive been experiencing poor starting for a while now and I suspect air in the fuel. When trying to find the source of this I found there was a wet patch in the mud surrounding the fuel sedimenter on the rear of the chassis. Its not a massive leak,not enough to leave any visible drops on the floor but im pretty sure its leaking a small amount. It seems to be coming from the pipes that run along the top of the chassis rails and my problem is how do I get access to them? Has anyone else experienced a leak here? and would you agree it could be the source of air in the fuel? Any suggestions on how to tackle this problem would be greatly appreciated. Many thanks. Tom. Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted November 30, 2010 Share Posted November 30, 2010 Find the leak with a torch in hand (You will have to clean the area well.) Then depending on where you find the leak, either replace the fuel sedimentor housing or the entire pipe which has the leak.... etc... Access is available where you need it. Quote Link to comment Share on other sites More sharing options...
