90MAD Posted November 30, 2010 Share Posted November 30, 2010 hi i was just wondering what every one else used and how you wires it all in, any info on parts used and some info on how you fitted it would be great cheers in advance Quote Link to comment Share on other sites More sharing options...
landy V8 Posted November 30, 2010 Share Posted November 30, 2010 hi i was just wondering what every one else used and how you wires it all in, any info on parts used and some info on how you fitted it would be great cheers in advance i've got twin fans from a sierra cosworth.used a 30amp relay with a switch on the dash.mine's a V8 so you may need less for a diesel.best thing is have a measure up of your rad and then head off down the nearest scrappy and pull one out. Ralph Quote Link to comment Share on other sites More sharing options...
Adam001 Posted November 30, 2010 Share Posted November 30, 2010 Can use anything you like really that fits. I use a single Kenlowe fan as they are designed for the job and I trust it not to short out with water a little more than a different solution. probably going to fit a second on the other side of the rad just as a back-up though before the summer. Wiring is simple, if you want to save costs just put it on a relay and switch it manually with a toggle and don't forget, or you can get a thermostatic controller which will do it for you, but they are a little more expensive. I just do it manually, find that works better for me. Adam Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 30, 2010 Share Posted November 30, 2010 I have a Kenlowe on there, but I haven't used it in about 2 years. 200Tdis are so over-cooled for our climate that it's just not needed. It's wired through a three-position switch that enables me to have it off, on via the thermostat, or override on. But as I said, it's been in the off position for a couple of years now Quote Link to comment Share on other sites More sharing options...
90MAD Posted November 30, 2010 Author Share Posted November 30, 2010 I have a Kenlowe on there, but I haven't used it in about 2 years. 200Tdis are so over-cooled for our climate that it's just not needed. It's wired through a three-position switch that enables me to have it off, on via the thermostat, or override on. But as I said, it's been in the off position for a couple of years now so would the steve parker kit be worth a buy or is that to over the top and just get a normal lecy fan and wire it myself with a relay and switch with just on and off and i would have it that i would just switch it on when needed Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 30, 2010 Share Posted November 30, 2010 That's what I'd do if I were doing another one. Any electric fan that will fit (from the scrapyard or whatever) should do the job. Some wire, a relay, a fuse and a switch and you're away. Simple is good Quote Link to comment Share on other sites More sharing options...
90MAD Posted November 30, 2010 Author Share Posted November 30, 2010 That's what I'd do if I were doing another one. Any electric fan that will fit (from the scrapyard or whatever) should do the job. Some wire, a relay, a fuse and a switch and you're away. Simple is good simple is good your right Quote Link to comment Share on other sites More sharing options...
Turnip Posted November 30, 2010 Share Posted November 30, 2010 Vauxhall Astra fan in alloy shroud fits right in to disco / 90 / 200 TDI rad - see pic. Tap top of thermostat housing - I think M22 x 1.5 - will check - dont have to drill - just tap as hole is correct size! Lots of switches available to suit. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted December 1, 2010 Share Posted December 1, 2010 that's really tidy, may find one of those for mine! Quote Link to comment Share on other sites More sharing options...
markyboy Posted December 1, 2010 Share Posted December 1, 2010 hi i was just wondering what every one else used and how you wires it all in, any info on parts used and some info on how you fitted it would be great cheers in advance Most people use a Mondeo fan and housing. Apparently they fit very simply and the housing/cowl is a good approximate size. I used one from a Peugeot 306 because it was free and available. It too was a very easy fit and the housing/cowl was a good approximate size for the back of the radiator. The downside of the "Pug" fan is that it is a "blower", not a "sucker". I've fitted it behind the radiator and reversed the polarity so it runs backwards. It is still more than good enough for the job, as Retroanaconda has said, the 200Tdi is overcooled. I have used a thermostatic switch from the same Peugeot and wired it through a relay with a simple override switch just in case. I forget what the switching temperatures were but they seemed to coincide well with my thermostat opening temperature. I got a threaded brass boss from my local radiator repair man, he had a bucketful of them and he gave me one for nothing. I soldered this into a piece of steel tube with the correct O.D. to fit into my bottom hose. Simply cut out a section of hose and insert the steel tube with a couple of hose clips. It works very well. The only time the fan has ever come on is when I have had the engine running at a very fast idle whilst the vehicle is stationary. Even then the fan only comes on for a few seconds before going off again. I haven't got any photo's of my setup but if you wanted some I could take a few and post them up for you. HTH. Mark. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 1, 2010 Share Posted December 1, 2010 The best option for automatic operation is the X-Eng fan switch. I'll echo what people above have said - grab a fan from the scrappy. Quote Link to comment Share on other sites More sharing options...
DavidW Posted December 1, 2010 Share Posted December 1, 2010 I've just done this and used a single mondeo fan in original housing, x-fan controller, in line fuse and a relay. A small piece of alu strip bolted and riveted at the bottom of the fan housing lets it sit in the brackets where the original fan cowling was. The mondeo fan is a surprisingly good fit. I'm going to add an overide and off switch to the cab when I get some more time. David Quote Link to comment Share on other sites More sharing options...
C18RCH Posted December 2, 2010 Share Posted December 2, 2010 I got all the parts for mine off ebay and a fan from a TVR. Works brilliantly. Quote Link to comment Share on other sites More sharing options...
90MAD Posted December 2, 2010 Author Share Posted December 2, 2010 I got all the parts for mine off ebay and a fan from a TVR. Works brilliantly. i will have to get my bits and do it in the new year as my viscos just clears the steering box and what bits did you order i was just gonna wire it so i turn it on when needed with a inline fuse Quote Link to comment Share on other sites More sharing options...
Turnip Posted December 2, 2010 Share Posted December 2, 2010 Id be pretty wary about putting any switch in the bottom hose? You really need it to be close to the thermostat as the temperature gradient in a 200 TDI rad is huge? Quote Link to comment Share on other sites More sharing options...
hammoj28 Posted December 2, 2010 Share Posted December 2, 2010 I have a single big fan off ebay on my V8,works really well. Got an adjustable radtek thermostat in the top hose too. Great bit o kit. http://www.rallydesign.co.uk/product_info.php?products_id=3449 Quote Link to comment Share on other sites More sharing options...
