landroversforever Posted December 1, 2010 Share Posted December 1, 2010 Does anyone have the dimensions of one of these? I need the thickness/length of the crush tubes and the ideally the PCD of the crush tubes, although and accurate measurement of a couple of hole centres would suffice Probably going to use one for a project at work Thanks in advance! EDIT: And what diameter are the holes? and size of the bolts used? are they the same as normal Prop shaft bolts? 3/8th UNF? Quote Link to comment Share on other sites More sharing options...
Biffo Posted December 1, 2010 Share Posted December 1, 2010 From my spare Bearmach one, Pt No STC2794 that I got for the 300 TDi Disco. Which I no longer need as I've done the propshaft/flange mod now. Length of tubes = 30mm Internal Dia of tubes = 12.02mm (So bolts would be 12mm) PCD = 96mm 6 holes, centre to centre of 2 holes = 48.25mm 'ish Hope this helps, (Curious to know what you're doing?) Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 1, 2010 Author Share Posted December 1, 2010 Thats perfect Biffo. much appreciated! Its a machine for rotating Waste drums to scan for Gamma Radiation. Going to use the joint in the drive shaft to allow a little misalignment, if the machine was to get damaged slightly from a drum being carefully dropped at height onto it Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 1, 2010 Author Share Posted December 1, 2010 Sorry, Any chance of the centre diameter too? another one I forgot! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 2, 2010 Share Posted December 2, 2010 I'd like to see you get a 12mm bolt in a 12.02mm hole!! Far more likely to be M10. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 2, 2010 Author Share Posted December 2, 2010 Any idea what the size of the bolts are? or a part number? I just assumed that this was the bolt used? http://www.lrseries.com/shop/product/listing/7039/FTC4043-BOLT-M12-X-65.html?page=4&search=propshaft&page=4 Quote Link to comment Share on other sites More sharing options...
Biffo Posted December 3, 2010 Share Posted December 3, 2010 I'd like to see you get a 12mm bolt in a 12.02mm hole!! Far more likely to be M10. you'll always find the bolt O/D's are actually undersize, only special location bolts are machined to spot size. The central hole dia is 50mm 'ish (it is rubber!) The bolts that were used (providing that I've found the correct ones!) are 12mm x 65mm long. (& just for bishbosh, the O/D of the 12mm bolt actually measures 11.91mm) Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 3, 2010 Author Share Posted December 3, 2010 The ones listed on LR series are M12 * 65mm only special stuff is bang on size Quote Link to comment Share on other sites More sharing options...
Biffo Posted December 4, 2010 Share Posted December 4, 2010 Obviously the length of the bolts will need to match the combined length of flanges etc plus doughnut width etc. so 65mm may not be correct. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 4, 2010 Author Share Posted December 4, 2010 oh, 65 wont be what I'm wanting . Quote Link to comment Share on other sites More sharing options...
