TD5 Crown pinion
Desert Cat
 Share
Hi,
Need to replace my 2001 TD5 front diff crown and pinion.
I'm to sure which P/N is required:
TBH100040
TBH100050
Are the following bearings P/N are OK?
539706 x 1 qty
539707 x 1 qty
FTC4822 x 1 qty
FTC52858 x 1 qty
41045 x 2 qty
Need some help identifying bearings P/N based on attached pictures.
Hi,
Oil seal FTC4822 is the halfshaft oil seal at the end of the axle casing (behind the CV joint).
You'll need to have two if you're going to change them when you withdrawn the halfshafts.
Scrumps
 Share
