sharpy Posted December 2, 2010 Share Posted December 2, 2010 Hi All, Any clues to what is wrong with the Bloody thing now? I drove about 10 miles, stopped for twenty minutes then started up, but the glow plug light didnt go off?, got home as I didnt want to break down all that way from home. Turned it off and started just fine with glow plug light staying off, great? Went to put it in gear and the clutch pedal travels about an inch and then stops, rock hard, almost like there is something under the pedal? so cant get any gears, there is fluid in the clutch resevoir and when the engine is not turning I can select all gears(without clutch) I tried starting it in gear and it lurched forward as I would expect it to. Cant see any sign of leaks under the truck, althogh I havent looked to hard as we have 2 feet of snow, but would have thought the snow would have made it an easier spot? Any clues or help very welcome as we need the truck going as its our only servicable car in this weather. Forgot to say it is an 1987 90 with a disco 1 engine 200tdi with about 85k on the clock Paul Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted December 2, 2010 Share Posted December 2, 2010 Dont knowabout the glo plug light, but the clutch is fooked. it;ll be the clutch fork, having been punched thro where it pivots on the ball pin. All got to come out I'm afraid, might as well get the lot done, complete clutch, new release bearing, Re -inforced clutch fork and DONT FORGET a new spigot bush!, Good luck. Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2010 Share Posted December 2, 2010 glowplug light staying on can only be a dying or dead timer relay, nothing else operates that light. sounds like your clutch fork has busted as mentioned above. Quote Link to comment Share on other sites More sharing options...
sharpy Posted December 2, 2010 Author Share Posted December 2, 2010 glowplug light staying on can only be a dying or dead timer relay, nothing else operates that light. sounds like your clutch fork has busted as mentioned above. thanks both, Whilst im changing the relay then should i go for a disco one? will it make a difference? Paul Quote Link to comment Share on other sites More sharing options...
sharpy Posted December 2, 2010 Author Share Posted December 2, 2010 also, whilst im at it will this item give me the ability to fully turn the key in the ignition and then at the pre-allotted time the engine turn over and start? 370461518959 Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted December 2, 2010 Share Posted December 2, 2010 I had a similar problem with the glow plug light on my 110 200tdi (disco conversion) Where my friend had re routed some of the cableing, the cable had melted slightly and was shorting on the engine block. When I replaced the cable in question, problem solved! As for the clutch, I would concour with the esteemed gentlemen above. Quote Link to comment Share on other sites More sharing options...
pinhead Posted December 2, 2010 Share Posted December 2, 2010 Only thing to add is my mate had a 300 tdi with a suspected bent release fork so I spent some time with him getting g box out to do the job to find it was fine Was a spring in master cylinder failed Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2010 Share Posted December 2, 2010 thanks both, Whilst im changing the relay then should i go for a disco one? will it make a difference? Paul same glowplug timer relay, so won't make any difference. Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2010 Share Posted December 2, 2010 also, whilst im at it will this item give me the ability to fully turn the key in the ignition and then at the pre-allotted time the engine turn over and start? 370461518959 right figured that number was a ebay item, so that one will be a straight replacement. to operate -- unlock vehicle, get in driving seat, put ign key in & turn so you see amber glowplug light red battery charge light red oil pressure light red handbrake on light [if switch is fitted] by the time your settled in & put seatbelt on, glowplug light will be out & then start engine, allow engine to idle for a few seconds & settle, then you can engage gear,release handbrake & drive off. Quote Link to comment Share on other sites More sharing options...
sharpy Posted December 2, 2010 Author Share Posted December 2, 2010 Cheers for that Ralph, the reason I asked was this is my first defender and I am in the position where I have been told to count to 15, some say split it into 8 and 7 seconds, cos the light never goes out whilst held on and never did in my mates trucks, maybe our trucks didnt have this timer relay fitted, hence the counting thing? Paul Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2010 Share Posted December 2, 2010 have you fitted the glowplug timer relay & associated wiring, I'm guessing Yes, also the thick brown/red trace wire needs to be seafely taped up & secured as it will still be live or disconnect from ignition switch & cover the ign switch terminal so it cannot short on anything else. read the wiing section here for more Tdi glowplug system info if not & your still on the old TD glowplug wiring, then you need to hold the key to make the glowplugs heat up for 10 to 15 seconds before starting. Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted December 3, 2010 Share Posted December 3, 2010 I have a brand new cluth kit in my shed John Quote Link to comment Share on other sites More sharing options...
