GARY ANDREWS Posted December 2, 2010 Share Posted December 2, 2010 any one know best place to get half shafts re splined cheers gary Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted December 3, 2010 Share Posted December 3, 2010 Slitty disc? Quote Link to comment Share on other sites More sharing options...
steve b Posted December 3, 2010 Share Posted December 3, 2010 Hi Gary How goes it ? You could try C.Rayment precision engineers , 01787327697 , they are not far from me ,but a bit of a trek for you cheers Steveb Quote Link to comment Share on other sites More sharing options...
GARY ANDREWS Posted December 3, 2010 Author Share Posted December 3, 2010 hi steve long been a while im fine still struggling on what to build but next in line is putting axles together.might put them under the 90 4 now till i know what all the new rules are going to be. will check them out cheers hows it going with u gary Quote Link to comment Share on other sites More sharing options...
steve b Posted December 3, 2010 Share Posted December 3, 2010 Oh lots of projects , even more ideas and never enough time Let us know how you get on . What axles are you hoping to nail the drop boxes onto? Cheers Steveb Quote Link to comment Share on other sites More sharing options...
GARY ANDREWS Posted December 3, 2010 Author Share Posted December 3, 2010 got apair of spider trax cases and i cant get that number to work Quote Link to comment Share on other sites More sharing options...
steve b Posted December 3, 2010 Share Posted December 3, 2010 ooops , paddle fingers strike again try 01787372697 cheers Steveb Quote Link to comment Share on other sites More sharing options...
nino Posted December 5, 2010 Share Posted December 5, 2010 a 1mm cutting disk on a angle grinder a grinding disk and a triangular file i had a funny noise at the wheel of my td5 but the drive flange was rusted solid on the shaft so i heated it and bashed it with copper hammer with no joy so had to cut it off and then fix the damage i did to the end of it with the said tools lol Quote Link to comment Share on other sites More sharing options...
Quagmire Posted December 6, 2010 Share Posted December 6, 2010 Google "Folkard gears" in Weybridge Surrey- postcode ~KT13. They do shaping and hobbing of internal and external splines and gears. Quote Link to comment Share on other sites More sharing options...
missingsid Posted December 7, 2010 Share Posted December 7, 2010 When I spoke to Ridgeway about extending existing splines they said that it can't/shouldn't be done due to stress release due to heat treatment causing warping? I did find a yank website which shows the depth of the heat treatment and says its not a problem? Car Craft Quote from article "The pen points out the 0.187-inch-deep factory surface hardening that is only mildly affected by the 0.040-inch-deep spline cuts (right). There is still plenty of strength left for all but the most serious horsepower levels. Again, the Suttons say this operation is safe for 3,400-pound cars running 11.0 seconds with an automatic or 12.0 seconds with more brutal stickshifts." The comments about loading regard 1/4 mile times as this is a Drag Racing project. Marc. Quote Link to comment Share on other sites More sharing options...
