nakedrunner Posted December 2, 2010 Share Posted December 2, 2010 Hi peeps. A relative in Orpington (miles away from me) apparently has a diesel Freelander 1 with a failed diff. There are tales of viscous couplings / IRD etc as being a more probable fault. She is in the hands of a local garage that seems unable to source a suitable, non new, item (new is too expensive). Assuming the diagnosed failed diff is correct can anyone suggest a likely source, breakers etc? Many thanks folks. I'm into series LRs so a bit unsighted on this. Quote Link to comment Share on other sites More sharing options...
JonT Posted December 3, 2010 Share Posted December 3, 2010 Recon rear diff at Bell Engineering for £325, plus £200 surchage if no excgange unit supplied http://www.bellengineering.co.uk Quote Link to comment Share on other sites More sharing options...
wriggs Posted December 3, 2010 Share Posted December 3, 2010 Yes! I too, will recommend Bell Eng. they fitted me a 2 wheel IDR unit for just over £500. 3,500 miles ago and she is still purring along nicely. They do the VCU's for around a £100 cheaper than Landrover. A very experienced and friendly family, i found. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 3, 2010 Share Posted December 3, 2010 Or save yourself a pile of cash and remove the diff, rear shafts, propshaft and VCU and have it as front-wheel-drive. I've done tens of thousands of miles like this in mine. The garage will need to gut the rear outer CV's (remove balls & cage) as the outer holds the wheel bearings together, but it's not a big job. Quote Link to comment Share on other sites More sharing options...
