lapperz Posted December 5, 2010 Share Posted December 5, 2010 ive noticed a water leak from the pipe where it go's into the water pump,at first i thought it was a crapi jubilee clip but no. ive looked under the vehicle and water was dripping from a bit higher up.this is where i need help please.on the bottom of the waterpump just behind the pully ive noticed a near perfect hole about 6 or 7 mm wide help what is it or is this normal help please. its a d90 with a 200 tdi disco engine thanks Quote Link to comment Share on other sites More sharing options...
fozsug Posted December 5, 2010 Share Posted December 5, 2010 Sounds like the bearing in the water pump is on its way out and has made the seal leak Quote Link to comment Share on other sites More sharing options...
lapperz Posted December 5, 2010 Author Share Posted December 5, 2010 (edited) Sounds like the bearing in the water pump is on its way out and has made the seal leak is that what the little hole is than pal and what do i need ,what go's in place of the hole Edited December 5, 2010 by western please refrain from posting text message shortcuts in your replies, it's not needed. Quote Link to comment Share on other sites More sharing options...
western Posted December 5, 2010 Share Posted December 5, 2010 you need a new water pump, the hole is a tell tale to let you know the pump seal have given up, nothing fits in the hole, it's doing exactly as designed, virtually all water pump have something like it. Quote Link to comment Share on other sites More sharing options...
lapperz Posted December 5, 2010 Author Share Posted December 5, 2010 you need a new water pump, the hole is a tell tale to let you know the pump seal have given up, nothing fits in the hole, it's doing exactly as designed, virtually all water pump have something like it. ok mate thank you just to confirm do i need the disco water pump or is the defender one the same as. thanks Quote Link to comment Share on other sites More sharing options...
western Posted December 5, 2010 Share Posted December 5, 2010 you need a Discovery 200tdi water pump, the Defender version is completly different shape. water pump Discovery 200tdi Quote Link to comment Share on other sites More sharing options...
