flatback90 Posted December 5, 2010 Share Posted December 5, 2010 mate has a 99 td5 auto and its recently stopped changing gear and feels like its stuck in 3 or drive,its awful slow to pull away and also has two flashing green lights on the dash both are a gear cog with M in one and S in the other a letter D also flashes below the milometer reading any one tell me whats wrong?? Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 5, 2010 Share Posted December 5, 2010 Only Testbook or similar will tell you what is wrong.The EAT ecu is in fault state.Can be many things,from a tired battery,chafed wiring loom,failed or waterlogged WXYZ switch or the ecu itself may have failed. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted December 5, 2010 Author Share Posted December 5, 2010 better get it booked in then.... thanks for the reply! Quote Link to comment Share on other sites More sharing options...
Unrequited Disco Lover Posted December 6, 2010 Share Posted December 6, 2010 mate has a 99 td5 auto and its recently stopped changing gear and feels like its stuck in 3 or drive,its awful slow to pull away and also has two flashing green lights on the dash both are a gear cog with M in one and S in the other a letter D also flashes below the milometer reading any one tell me whats wrong?? Had the same problem a year or so back, when the M and S lights flash that puts the system in "limp home mode" and will car only stay in third gear. On my car it was the gear select inhibiter switch($au 414) that caused the problem, until issue was resolved I found that problem only occured when selecting drive after reversing from garage, if, after reversing from garage I then did the Bill Gates trick and selected drive after restarting, system was Ok. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted December 6, 2010 Share Posted December 6, 2010 Yes we fixed a Disco with the same problem - switch on gearbox was faulty. Quote Link to comment Share on other sites More sharing options...
kevin31031961 Posted March 13, 2011 Share Posted March 13, 2011 Hi just had same problem changed xyz but it was the ecu under front seat passengers Quote Link to comment Share on other sites More sharing options...
