sussex-landy Posted December 6, 2010 Share Posted December 6, 2010 I have changed over the dizzy as part of my engine replacement and need to align the timing with the top dead centre of the engine which I have done based on the book but I have seen lots of ways to test this and wanted to know if anyone else had changed a V8 over and replaced the dizzy with their original one. Is this something I should pay a garage to do, Thanks Robert Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 6, 2010 Share Posted December 6, 2010 Don't think you need to take it to a garage, it's not complicated. Just get yourself a timing light and set it up as per the book. Quote Link to comment Share on other sites More sharing options...
sussex-landy Posted December 6, 2010 Author Share Posted December 6, 2010 Is it really that easy. Just wanted to check from someone thats done it before I go to the trouble. Thanks Robert Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 7, 2010 Share Posted December 7, 2010 Is it really that easy. Just wanted to check from someone thats done it before I go to the trouble. Which part of it is causing you trouble? A search of the forum (probably Range Rover forum would be best) should yeild a few posts on timing. Personally I'd ditch the lot and go Megasquirt'n'EDIS, set the timing from the laptop Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 7, 2010 Share Posted December 7, 2010 Personally I'd ditch the lot and go Megasquirt'n'EDIS, set the timing from the laptop Once you've used a timing light and jiggered the trigger wheel/sensor to get the timing to 10 DBTDC Quote Link to comment Share on other sites More sharing options...
