rallyboygower Posted December 7, 2010 Share Posted December 7, 2010 Hi Guys new to the forum so have some knoledge of freelanders that i can hopefully help others with.Changed the front drive shaft on my 02 TD4 but forgot to remove the abs sensor,that got damaged when i inserted the new shaft, so new well second hand sensor obtained off flybay, fitted that the three dreaded lights went out after a short spin but all of a sudden a loud grinding sound came?. It sounds like a spline of the drive shaft catching on something?, the noise goes up and down with the engine speed?. The strange thing is that when i pull the abs fuse out the noise totally goes? so must be related to the abs system? does anyone know if the abs system takes a drive off the engine because the noise is only there when the fuse is replaced?....could you please help me with this one as its a bit scary having no abs or traction control in these tricky conditions.. Thanks in advance guys. Math... Quote Link to comment Share on other sites More sharing options...
rallyboygower Posted December 9, 2010 Author Share Posted December 9, 2010 Thanks for all your replies guys!!!! Quote Link to comment Share on other sites More sharing options...
