JeffR Posted December 7, 2010 Share Posted December 7, 2010 Now we all know that the heating inside a LR is , well, useless, but this is how cold it is inside mine - after a 40 mile round trip with the heater set on blast furnace - really need an advert on this site for LR branded thermal undies!!!!! Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 7, 2010 Share Posted December 7, 2010 Can you reduce the image size? they are so big I'm scrolling across the screen..... Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted December 7, 2010 Share Posted December 7, 2010 You need to get your heater sorted, mine blasts out really warm air after a mere five miles!! i also find that having it turnedd off totally for the first few miles helps!! Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 7, 2010 Share Posted December 7, 2010 the condensation on my roof keeps freezing, its like getting into a freezer box in the mornings Quote Link to comment Share on other sites More sharing options...
JeffR Posted December 7, 2010 Author Share Posted December 7, 2010 Thought I had reduced the image size (blame Bill Gates, not me). Believe it or not, the heater is fine, just had a new matrix, all linkages re-adjusted etc, etc, its just bloody cold. Should have seen it last weekend, wife flatly refused to get in until I removed the 8 inch icicle hanging from the hinge. And as for the windscreen washers, even running 80% screenwash results don't work, but I have a cunning plan to rectify that, this weekend I'm fitting my heated washer system - 10 inches of copper tube coiled around the matrix inlet pipe - instant heat exchanger!!!!!! forgot to add that the condensation (how the hell it gets in there I don't know) inside the dash dials has also frozen, but couldn't get a decent photo Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 7, 2010 Share Posted December 7, 2010 Thought I had reduced the image size (blame Bill Gates, not me). Believe it or not, the heater is fine, just had a new matrix, all linkages re-adjusted etc, etc, its just bloody cold. Should have seen it last weekend, wife flatly refused to get in until I removed the 8 inch icicle hanging from the hinge. And as for the windscreen washers, even running 80% screenwash results don't work, but I have a cunning plan to rectify that, this weekend I'm fitting my heated washer system - 10 inches of copper tube coiled around the matrix inlet pipe - instant heat exchanger!!!!!! careful putting warm liquid on freezing cold glass! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 7, 2010 Share Posted December 7, 2010 Can I point Sir in the direction of an Eberspacher or Webasto - knocks all this hardship on the head, especially with a remote keyfob for start it Quote Link to comment Share on other sites More sharing options...
JeffR Posted December 7, 2010 Author Share Posted December 7, 2010 Now I approve of the that idea, sadly, bank manager does not. The idea behind the coiled (and insulated) copper brake pipe is that to attach it to the washer pipes so that warm water flows through, I did some calculations and reckon that the heat loss over 12 inches of plastic piping would be large enough to ensure that the screenwash fluid did not cause thermal shock to the windsceen, mind you a heated windscreen would be easier, but nowhere near as much fun, and again I suspect that the bank manager would be less than enthusiastic.... Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 7, 2010 Share Posted December 7, 2010 I don't have a problem with condensation on my roof. That's probably because it's in my storage shed. Yup - still open top, and no heater at all. Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 7, 2010 Share Posted December 7, 2010 I don't have a problem with condensation on my roof. That's probably because it's in my storage shed. Yup - still open top, and no heater at all. you must be hard as nails or thick as two short planks I'm so cold I've taken to wearing tracksuit bottoms under my trousers ha ha Quote Link to comment Share on other sites More sharing options...
GBMUD Posted December 7, 2010 Share Posted December 7, 2010 The idea behind the coiled (and insulated) copper brake pipe is that to attach it to the washer pipes so that warm water flows through, I did some calculations and reckon that the heat loss over 12 inches of plastic piping would be large enough to ensure that the screenwash fluid did not cause thermal shock to the windsceen But unless you use the washers every 30 seconds then the nozzle will still freeze solid and you will have a 12" pipe full of hot spray with nowhere to go - hur hur hur... I have been making do with a plastic bottle full of water with a hole in the lid. Whenever I am stopped at lights etc., just lean out and give the window a good irrigating. Of course, the wiper arms still freeze so there is little contact with the glass. Chris Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted December 7, 2010 Share Posted December 7, 2010 Well just like it's predecessor my current Puma warms up and the heater blasts out hot air PDQ ...oh and the heated seats are nice too ....as it the heated screen. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 7, 2010 Share Posted December 7, 2010 you must be hard as nails or thick as two short planks I'm so cold I've taken to wearing tracksuit bottoms under my trousers ha ha I probably ought to add that I'm away on work, so not actually driving around in it at the moment. Should I do so though, It'll be full ski gear! Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 7, 2010 Share Posted December 7, 2010 I've just been using nearly neat washer fluid in my screenwash and it hasnt frozen yet. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted December 7, 2010 Share Posted December 7, 2010 i spent 3 years in germany when i was in the raf,there is a german alcoholic spirit known as white corn,was actually cheaper than screen wash so that is what we all used in the washer bottle,was as rough as guts to drink though!!my current 90 is still wearing a full canvas this winter,not found it much colder than the hard top last year,with the viscous fan removed it warms up fairly well,but i think the average over night temp in coastal suffolk is about -2 so far,a far cry from my native s****horpe,that was -16 at 6a.m monday morning. Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 8, 2010 Share Posted December 8, 2010 i spent 3 years in germany when i was in the raf,there is a german alcoholic spirit known as white corn,was actually cheaper than screen wash so that is what we all used in the washer bottle,was as rough as guts to drink though!!my current 90 is still wearing a full canvas this winter,not found it much colder than the hard top last year,with the viscous fan removed it warms up fairly well,but i think the average over night temp in coastal suffolk is about -2 so far,a far cry from my native s****horpe,that was -16 at 6a.m monday morning. You mean Jenever? That should indeed do quite well, with the alcohol that has in it there would need to be a new ice age to freeze it A few of the SLRC members can attest to its tastiness Quote Link to comment Share on other sites More sharing options...
simonr Posted December 8, 2010 Share Posted December 8, 2010 My top tip is to fit a new Thermostat! OK, you' probably have already - but this time buy one from a main dealer. I've had this several times with different LR's and every time, a new, genuine stat has fixed all my heating problems. Ones from Halfords, Britpart, Local motor factor are all worthless - I've only found genuine ones work properly. It's a lot cheaper than a Erberwebastospreachnheatenkugelschiber at the end of the day! Si Quote Link to comment Share on other sites More sharing options...
JeffR Posted December 8, 2010 Author Share Posted December 8, 2010 Got one in the cubby box, but as the f**kin bonnet is frozen shut (hit minus 12 last night), fitting it is another job for when things begin to thaw out.... Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted December 8, 2010 Share Posted December 8, 2010 It's a lot cheaper than a Erberwebastospreachnheatenkugelschiber at the end of the day! Si LMAO......... (how long to type that and such a legible word) i just bought a Webasto as its easier to say.........should be here next week. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted December 9, 2010 Share Posted December 9, 2010 Have a look on Ebay USA engine heaters , I have just bougfht one for £17+£6 for delivery , 110v so you need a building site transformer £20? and your engines at working temp in about 50 mins fits in heater hose . lot cheaper than a kenlowe hotstart . juts remeber to unplug lead before driving off Quote Link to comment Share on other sites More sharing options...
nicks90 Posted December 10, 2010 Share Posted December 10, 2010 if you are wanting a simple 240v plug in engine heater - why not build one yourself for next to nothing? Cant be that hard to make a simple fitting in the bottom hose of your radiator and insert a small slimline immersion heater into it. Cut the bottom hose and insert a flexible T piece into it with the heater element sealed into the T. As its in the bottom hose, natural convection current should warm up all the coolant quite effectively. Little 500w 240v immersion heaters can be had for £5. Cut the plug off it and wire it to an exterior socket box mounted on the inner wing and away you go! bet you could do it for less than a tenner. Quote Link to comment Share on other sites More sharing options...
