reb78 Posted January 11, 2011 Author Share Posted January 11, 2011 Pretty sure it is the correct drop arm, although its hard to tell - if i look up pics of the part numbers for LH and RH versions on lrseries, they look pretty much identical. Two clockwise turns from left lock without the drag link connected will mean that when set to 924mm, the wheels would point slightly to the left, not straight ahead and, even if i ignored the 924mm setting, i just dont think i can shorten the drag link anymore as there are no threads left showing at the drop arm end on the crossrod eye. I'm at a bit of a loss! Quote Link to comment Share on other sites More sharing options...
