liseanddavid Posted December 9, 2010 Share Posted December 9, 2010 Hello all, I've just had a lovely glavanised chassis put on. However I am disappointed to find that my reverse lamp (no 12V to socket) and both dash indicators lamps are not working for the hand brake(lamps ok). Is there a common socket that has been left disconnected on top of the gearbos for these. Grateful for any advice, a bit dissappointed with the people that done the job, should have all been checked. Thanks Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 9, 2010 Share Posted December 9, 2010 Hello all, I've just had a lovely glavanised chassis put on. However I am disappointed to find that my reverse lamp (no 12V to socket) and both dash indicators lamps are not working for the hand brake(lamps ok). Is there a common socket that has been left disconnected on top of the gearbos for these. Grateful for any advice, a bit dissappointed with the people that done the job, should have all been checked. Thanks There is a quick connector for you reversing lamp just close to the actual switch, best accessed through your center seat box hatch, I don't have a handbrake indicator, but I'm guessing there is a similar connector in roughly the same location but closer to the handbrake. Quote Link to comment Share on other sites More sharing options...
western Posted December 9, 2010 Share Posted December 9, 2010 shift the handbrake rubber boot, the terminal maybe unconnected & check the white/yellow trace wires at the bulkhead multiplug. reverse light coneection near the switch maybe unconnected as well, Quote Link to comment Share on other sites More sharing options...
liseanddavid Posted December 9, 2010 Author Share Posted December 9, 2010 Thanks to both of you will have a check tomorrow and let you know - hopefully the snow will have melted.. Quote Link to comment Share on other sites More sharing options...
liseanddavid Posted December 10, 2010 Author Share Posted December 10, 2010 When I take of the driver seat access pleate the yellow wire for the handbrake is lying disconnected - it seems to have a push in fitting - I can't see where it goes - any ideas? The wire is not that long. Also looking across to the passenger side from here I can see a disconnected plug - am presuming this is the reverse light and just have to find the switch end? Quote Link to comment Share on other sites More sharing options...
liseanddavid Posted December 10, 2010 Author Share Posted December 10, 2010 Have just found these connection, one push in connection for the handbrake and both male and female connection for the reverse light just hanging loose. Thanks for the advice. The electronic control unit under the middle seat on my 300tdi, is this for the EGR valve? He's just cut through that and left it - i think this is redundant? Isn't it? Quote Link to comment Share on other sites More sharing options...
western Posted December 10, 2010 Share Posted December 10, 2010 Egr ECU & Valve on engine can be totally removed & hole in manifold blanked off. good to read you found the unfitted connections, maybe a letter to whoever did the conversion just to say you would expect the vehicle to have everything returned in full working order. Quote Link to comment Share on other sites More sharing options...
