orangebox Posted December 10, 2010 Share Posted December 10, 2010 Hi. After giving a newly purchased 1987 90 a jetwash in preparation for a bit of Waxoyling I discovered two areas of penetrating rust which has been previously filled and painted over (b*******). So, a couple of questions if I may: 1) Is this an MOT fail? 2) If I KURUST (or similar) the holes, would a welded patch over each hole (3mm steel) suffice? 3) If not, is replacing the outriggers horrendously expensive (it's way beyond my capabilities)? Many thanks. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted December 10, 2010 Share Posted December 10, 2010 Hi. After giving a newly purchased 1987 90 a jetwash in preparation for a bit of Waxoyling I discovered two areas of penetrating rust which has been previously filled and painted over (b*******). So, a couple of questions if I may: 1) Is this an MOT fail? 2) If I KURUST (or similar) the holes, would a welded patch over each hole (3mm steel) suffice? 3) If not, is replacing the outriggers horrendously expensive (it's way beyond my capabilities)? Many thanks. I think any holeing of the chassis or its components might be an MOT issue. They don't look that bad tbh but its what you cant see is the stuff you need to sort out I am sure most people on here have had that sinking feeling when bits of the chassis cave in under pressure washing. They can be quite costly to get done in a garage but if you find a person that can weld you might be able to get it done for a fraction of the cost. Some people patch the outriggers and some replace. I replaced mine and I am glad I did as their was a huge 4" square hole behind the outrigger in the chassis wall and having posted here I found it is fairly common. I would also have a good look at your chassis from front to back with a good torch and screwdriver or some use a pin hammer tapping as you go and listen for tone change or as hole appear! sorry just kidding. The upside is its all do-able I don't know where you are but if it helps I can let you have the welder/fabricators details if you are near-ish pm me for the info. I don't know what the answer is about rust treatment some say cut it out or it will spread others take the view that it is just a chemical process that needs oxygen and moisture to continue so if you deny it both by treating it,it stops. I have used that rust converter that changes the rust to a black hard skin that doesn't rust that's quite good stuff and then used cold galvanising paint that's also good stuff and you can get it from most diy shops including "screwed-fix" I am sure wiser heads than mine will give you lots more info but its a start, good luck and dont let it get you down and dont forget if you are near-ish pm me and I will let you have said welders details. Cheers J Quote Link to comment Share on other sites More sharing options...
western Posted December 10, 2010 Share Posted December 10, 2010 remove the rusty stuff, weld in new material otherwise it'll fail or get you a advisory. Quote Link to comment Share on other sites More sharing options...
orangebox Posted December 10, 2010 Author Share Posted December 10, 2010 Thanks guys. I'm going to have a proper look/tap/prod underneath over the weekend and see what needs doing. I appreciate your responses. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted December 10, 2010 Share Posted December 10, 2010 Mine passed this year with this hole: Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 10, 2010 Share Posted December 10, 2010 Really shouldn't, the outrigger is a body mount point so is rather important. Mine failed with this one two years ago: Get it fixed, either by a garage (can be expensive) or by a welder-wielding friend. Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted December 11, 2010 Share Posted December 11, 2010 3) If not, is replacing the outriggers horrendously expensive (it's way beyond my capabilities)? I just bought a new pair of outriggers at £42 each from DLS. Not mahoosively expensive but still a fair chunk. The point though is if you're paying somebody to weld for you it'll probably be quicker and therefore cheaper in terms of labour to weld in new rather than patch old ones... Just my two-penneth Edited to add: I should probably mention I had to replace my outriggers because they'd both been badly patched before. By a pigeon with diarrhoea, juding by the state of the welds... Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted December 11, 2010 Share Posted December 11, 2010 i repatched my outrigger this mot.first pattching lasted about 6-7years only patched as hoping to put new chassis and i'm doing the welding myself so is cheap Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted December 11, 2010 Share Posted December 11, 2010 Found it have a look at this little horror lurking under the outrigger http://forums.lr4x4.com/index.php?showtopic=39803&st=0&p=377353&fromsearch=1entry377353 Quote Link to comment Share on other sites More sharing options...
