cypermethrin Posted December 10, 2010 Share Posted December 10, 2010 Having replaced the glow plugs, ignition barrel and glow plug relay the glow plugs are still not receiving 12v This is what I know :- The dashboard lights (incl the glow plug one) all work perfectly There is continuity between the glow plugs and the black/yellow wire on the relay The yellow/black wire from the relay clearly works as that feeds the dash instrument pack The black wire from the relay has a good earth The white/red wire from relay to ignition Position II to crank the engine is working fine as the engine turns over The white wire from relay to fuse 17 and Position I on ignition is working OK as dash glow plug light working ok I understand looking at the 300tdi wiring diag that one of 60 Amp fuses in the engine compartment fusebox feeds the glow plug relay on the brown wire SO by a process of elimination it must be this 60 Amp fuse that has blown - does this fuse feed any other cicruit ? By writing this I think I have convinced myself that this is the source of the problem - unless you can tell me otherwise! Thanks Quote Link to comment Share on other sites More sharing options...
western Posted December 10, 2010 Share Posted December 10, 2010 wiring diagram might help. fuse 60amp feeds the glowplug relay as does the 15amp fuse in passenger comp. fusebox Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted December 10, 2010 Author Share Posted December 10, 2010 Thanks western thAt was the circuit diagram I was referring to. Do you recon my diagnosis is correct? Quote Link to comment Share on other sites More sharing options...
western Posted December 10, 2010 Share Posted December 10, 2010 if the relay isn't getting any amps then it could be a dead fuse [60amp] or a very poorly relay or connections to the fusebox. Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted December 10, 2010 Author Share Posted December 10, 2010 I'll take a look tomorrow thanks again western Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted December 11, 2010 Author Share Posted December 11, 2010 Replaced the 60 amp blown fuse and now glow plugs working a treat Also fitted new earth 40 mm2 cable from starter earth to battery -ve Fingers crossed all this will have cured the reluctant start in the mornings Thanks again western for all your help and support Quote Link to comment Share on other sites More sharing options...
western Posted December 11, 2010 Share Posted December 11, 2010 Good to know all is as it should be, happy to help Quote Link to comment Share on other sites More sharing options...
jbs Posted December 13, 2010 Share Posted December 13, 2010 How did you get on with the earth onto the starter motor from -ve ? as I'm considering doing the same when I get home to sort a few things out. Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted December 13, 2010 Author Share Posted December 13, 2010 Was surprisingly straight forward. Used those nice chaps at vwp to make up the 2m of 40mm2 starter cable with an 8 mm terminal end which went straight on the starter earth. Fed the cable along chassis and up into battery box. Cut off the 20 cm of cable which was not needed and then use another 8 mm terminal end and a friends crimping tool and job done. Secure new cable appropriately along way with cable ties etc. Checked all other earths while I was about it and now the starter motor is alot stronger and faster Quote Link to comment Share on other sites More sharing options...
chosenview Posted August 4, 2016 Share Posted August 4, 2016 I'm trying to figure out the operations of the glow plug timer unit for my project car. The original engine came out of a disco 1 300tdi that is now long gone. I'm pretty sure that when I energise the relay it clicks on for about 5 seconds then clicks off. Also pretty sure that glow plugs do fire up for that period. So that's the normal relay contacts dealt with and the timer function. Now I'm left with a white/green cable and a black/yellow cable. According to the diagram earlier in this thread the White/green is spliced into the same circuit as the starter solenoid so is presumably an input to the glow plug relay. The B/Y wire goes to the warning light on the dash. In my case a 5w side light bulb. I'd have thought energising the W/G wire (cranking) would then shut off the B/Y output or it would also shut off after the timer completed. My does not do this. If I connect the B/Y wire through the bulb to earth then the bulb is perminantly on when the relay is energised. If I connect it back to the W/G ( as per diagram above) it never comes on Anyone any insight into what I have wrong? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 4, 2016 Share Posted August 4, 2016 Maybe I misunderstand but the warning light should be on when the relay is energised. Mo Quote Link to comment Share on other sites More sharing options...
western Posted August 4, 2016 Share Posted August 4, 2016 Correct Mo glowplug warning light is driven by the timer relay, Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 4, 2016 Share Posted August 4, 2016 So what is the problem then ? ? Quote Link to comment Share on other sites More sharing options...
