biggles Posted December 11, 2010 Share Posted December 11, 2010 I Was looking to get a Lodar remote, could anyone tell me which would be the best model to go for to control a twin motor 8274 motors are xp's solenoids albright. thanks for a ny help Quote Link to comment Share on other sites More sharing options...
western Posted December 11, 2010 Share Posted December 11, 2010 depends what you want, my lodar is the older 8000 models with in/out only, you can get them with a emergency stopp override too, have a look here http://www.lodar.com/transmitters.htm Quote Link to comment Share on other sites More sharing options...
biggles Posted December 12, 2010 Author Share Posted December 12, 2010 depends what you want, my lodar is the older 8000 models with in/out only, you can get them with a emergency stopp override too, have a look here http://www.lodar.com/transmitters.htm Thanks for reply, looked on lodar's site but still can't seem to find out which unit can operate two solenoids, prob drop them an email biggles Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 12, 2010 Share Posted December 12, 2010 I've got a Lodar 9000 on my Milemarker and would recommend it 100% Instant and reliable response, excellent range, you can switch it on and off from the remote and if you forget it shuts down automatically after about 30 min to avoid flattening your battery. Great bit of kit, you'll never plug a controller in again (I haven't - 3 years now I think) The only minor criticism is that on long pulls I would prefer a toggle switch (like on a normal hand controller) rather than a push button as your thumb gets tired but that really is the only issue I have with it. Quote Link to comment Share on other sites More sharing options...
western Posted December 12, 2010 Share Posted December 12, 2010 Thanks for reply, looked on lodar's site but still can't seem to find out which unit can operate two solenoids, prob drop them an email biggles maybe the signal in for the solenoids can be wired so both switch at same time, can't see why the lodar wouldn't work that way, it doesn't know there are 2 motors/soleniods to control. Quote Link to comment Share on other sites More sharing options...
simonr Posted December 12, 2010 Share Posted December 12, 2010 Any of the 90 series will switch a twin-motor with two solenoids. The solenoid coils are just connected together. Each output on the Lodar will switch 5A which should be enough. For the difference in cost, I'd be inclined to buy a 4 or 6 channel setup. that means you can control two or three winches or even a freespool or two if required. Si Quote Link to comment Share on other sites More sharing options...
biggles Posted December 12, 2010 Author Share Posted December 12, 2010 Thanks for all help, I emailed lodar and just got reply, which I thought was pretty good as it's a Sunday, basically what si has said is what I've been told by the tech guy at lodar even down to Albright amp ratings. Thanks again Biggles Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 13, 2010 Share Posted December 13, 2010 If it is a concern you could always have a bank of 30A relays switched by the Lodar outputs to control solenoids? The Milemarker hydraulic solenoid only sucks about 2 amps so it is fine with the standard setup, not sure how much electric winch solenoids take. Quote Link to comment Share on other sites More sharing options...
simonr Posted December 14, 2010 Share Posted December 14, 2010 If it is a concern you could always have a bank of 30A relays switched by the Lodar outputs to control solenoids? The Milemarker hydraulic solenoid only sucks about 2 amps so it is fine with the standard setup, not sure how much electric winch solenoids take. About 2A holding. Si Quote Link to comment Share on other sites More sharing options...
