Simon B Posted December 12, 2010 Share Posted December 12, 2010 This knotty problem again! Always rotts, is thinner than other chassis members and is a pig to get out. Remove the sill panel and door fill panel (the little triangular one whose rivets always fall out, you only need to do this on one side, but it helps with visibility if you do both Dont bother trying to undo the various nuts and bolts simply cut them all off. Prepare your cross member; if you have not got one that has separate brackets drill through them and grind off the welds to separate. Remove the small rectangular brackets the bolt to the section that supports the now removed sill Cut it exactly in half through th middle and prep the ends for the final weld. Now for the fiddly bit, insert the cross-member if you are only working from one side get underneath and put in the section furthest from the removed sill and fill panel, it can be just put in place by first putting it in longways on between exhaust and propshaft. The screws securing the floor were fouling the top so I had to trim these down. The were badly coroded so arent going anywhere. You may need to make some re-infrocing plates out some aluminium as the body work behind the brackets often corodes away into white solihull powder. All bolted up loosely so that weld can be aligned. Not the best weld I've done but its strong enough and all covered in waxoyl - so no going back! All rivetted back together now, that'll keep my MOT man happy now. If I was doing this job again I'd consider getting a galvanised one with removable brackets and try getting in all in one first. You could dispense with the need for a weld if you made a section that bolt the two halves back together. Hope this helps and is considered fit for the technical archive. Quote Link to comment Share on other sites More sharing options...
western Posted December 12, 2010 Share Posted December 12, 2010 no need to get one made, YRM Metal solutions has this one in their range now with bolt on brackets & all galvanised too http://www.yrm-metal-solutions.co.uk/053-defender-110-mid-crossmember-204-p.asp IIRC there was/is a 3 piece stainless steel version out there in LR 110 parts land, can't remember who makes/made them, next time mine needs changing it'll be a Galvy YRM one going on. Quote Link to comment Share on other sites More sharing options...
Simon B Posted December 12, 2010 Author Share Posted December 12, 2010 no need to get one made, YRM Metal solutions has this one in their range now with bolt on brackets & all galvanised too http://www.yrm-metal...ember-204-p.asp IIRC there was/is a 3 piece stainless steel version out there in LR 110 parts land, can't remember who makes/made them, next time mine needs changing it'll be a Galvy YRM one going on. Western, I'd seen the YRM one in one of your previous posts but had already got the replacement one for mine Three pieces would be easier if you do not want to remove the sill and fill panel. Quote Link to comment Share on other sites More sharing options...
LostChord Posted February 24, 2020 Share Posted February 24, 2020 Bumping a really old thread with a question: can't quite tell from the pic, but did you simply put this bolt in upside down (i.e., nut on top of crossmember) since it is directly underneath the heelboard ? Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2020 Share Posted February 24, 2020 Yes I put both of those bolts in head down on both sides when I fitted my YRM cross member. 1 Quote Link to comment Share on other sites More sharing options...
LostChord Posted February 24, 2020 Share Posted February 24, 2020 21 minutes ago, western said: Yes I put both of those bolts in head down on both sides when I fitted my YRM cross member. Good to know....thanks! 1 Quote Link to comment Share on other sites More sharing options...
Lightning Posted May 31, 2020 Share Posted May 31, 2020 Just done this job on my 110. Those two bolts are just on the edge of the floor (after you’ve removed the main floor panel) and l drilled a couple of 16mm holes in the floor edge to get the bolts out. The holes are covered up when you refit the main floor panel, although l put grommets in them anyway. Also the body dropped very slightly when l removed the old crossmember, nobody said that would happen! It was only a few mm but, The rear doors were hitting the catches. It’s actually the front body that drops not the rear. I had to jack it up a little with my trolley jack to get the bolts back in to the crossmember and after that it was OK and the door closing was fine. Quote Link to comment Share on other sites More sharing options...
