CJRH Posted December 12, 2010 Share Posted December 12, 2010 I've had a search through but can't find the answer I'm after. I've fitted a new radio to my 2003 TD5 ES spec disco. It has the Harman Kardon amplified system in it. The problem is I am now putting an aleady amplified signal into the amp and so everything is a bit loud........... As far as I can work out I can not turn down the output from the radio, (Philips CEM3000B). Does anyone know if there is a converter for the RCA output on the radio to speaker input? Or any other ideas? Cheers, Chris Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 12, 2010 Share Posted December 12, 2010 re-read the original post and what I said was wrong. sorry. Quote Link to comment Share on other sites More sharing options...
CJRH Posted December 14, 2010 Author Share Posted December 14, 2010 Sorted this out. On the back of the new radio are front and rear phono outputs. I made up a lead to go from the phono outputs to the speaker plug so that the Harman Kardon amp gets a low level input. Quote Link to comment Share on other sites More sharing options...
