Defender 3.9V8 auto
JackD90
 Share
Hi, ive decided to bring my defender v8 auto back to the road after sitting for a year, just a little problem or could be a big problem, it starts fine, runs ok, then it wil start splutting and nearly die's? leave it for a while then seems to be fine then it will start spluttering again?
can some 1 help or offer some susgestions?
thanks
jack
thanks
jack
If its the original fuel used then this may have degraded.
1. Check or replace filters.
2. Injection on idle carbs could be narrowed from lack of use.
3. Blocked air filter.
4. If auto fuel inject blockage or fueltank pump power faulty.
5. Choke usage not fully used so still running on a cold engine.
6. Auto choke could have a damaged diaphragm.
Hope these help :rolleyes: . but could you reply stating type of engine 3.5 3.9efi or above and age of vehicle. :huh::blink::unsure:
regards fellow v8 fuel burner :D :D :D :D :D
So Sorry just notice your header. Slight problem with Mark One issued eyeballs. Must remember to look up next time. :rolleyes::( :( :( :( :blink: :blink: :blink: :blink: :blink: :blink: :blink:
  • 1 month later...
thanks for the replys, found the problem, after changing loads of stuff on the truck, it turned out to be 1 of the fuel pump wires bin choped/snaped in half, and was touching on the chassis to earth, and when going over bump not touching earth and then playing up.
 Share
