is a 200 tdi injector pump the same as ......
hello
right i'm in the process of rebuilding a 300 tdi engine and have taken off the old edc pump as I want to get rid of any electronic wizardry :ph34r:
I've fitted a 200 tdi pump off a friend but somebody mention today that they may be different :( something about pressures :unsure:
So is a 300 tdi injector pump the same as a 200 one ? has anybody on here done the swap and got a functioning engine ? :D
Cheers
Gary
It will work, been done by some before,
200Tdi pump is a VE 4/11F1900R 347-1 pressure 650bar injectors run at 200bar 1st stage & 280 bar 2nd stage
300Tdi pump is a R509/1 with EGR or R509 non-EGR, pressure virtually the same, injector working pressure as above.
