james.lw Posted December 16, 2010 Share Posted December 16, 2010 hi guys can a defender 2.5 turbo silencer can be used with a defender 200 tdi kind regards james Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted December 16, 2010 Share Posted December 16, 2010 I think the answer is yes, or at least, I did! When I swapped my 2.5TD for a 200Tdi, the only change was the downpipe, I left the rest of the system the same. Cheers Peter Quote Link to comment Share on other sites More sharing options...
james.lw Posted December 16, 2010 Author Share Posted December 16, 2010 I think the answer is yes, or at least, I did! When I swapped my 2.5TD for a 200Tdi, the only change was the downpipe, I left the rest of the system the same. Cheers Peter thanks peter did you have any pic of it Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted December 16, 2010 Share Posted December 16, 2010 No, sorry I didn't take any pictures at the time. I put in a Defender 200Tdi and I do remember it was a very simple job! The only problem I've had is that occasionally the downpipe comes loose from the bolt that secures it to the block and it sounds like a tractor until it's cool enough to push it all back together again! Cheers Peter Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 16, 2010 Share Posted December 16, 2010 I used the complete TD system (including downpipe) on my defender 200tdi conversion. That system will work fine with the 200tdi. Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2010 Share Posted December 16, 2010 Yes, it can be used, but the pipe internal borre is slightly smaller, but doubt you or the engine will notice. Quote Link to comment Share on other sites More sharing options...
