200TDi Conversion using 19J PAS pump?
Evening,
After i blew up my 19J (again!) i decided to get a 200TDi, managed to get the engine in last week and i am currently in the proccess of plumbing it in.
I have come across a slight problem, The engine i bought did not come with a PAS pump. Is there anyway to use the 19J pas pump? I have bolted the bracket on. The pulley lines up with the front crank pulley (And water pump) however there is no way that i can get the alternator to line up.
Cheers
Matt :)
these pics might help, Disco 200tdi into a older 90/110, using the Discovery bits,
have you tried fitting the disco alternator on the 19J bracket ?
how far out of line are the Alternator & water pump pulleys ? is the sliding split bush in the alternators rear attachment point as far back so the inner face is flush with the attachment point ?
are you able to add a couple of pics, so we can see the problem?
 Share
