water pump pulley - with additional air-con drive flange
poohbear
 Share
As in the title really -
need a part number for the water pump pulley pulley. The one I currently have only will ony run one v-belt and I'd like to swap this for the version that also drives the air con pump.
From what I can see the archives all refer to defender based lumps whereas mine has a disco tranplant.
Help greatfully received as always.
Dave.
Air con pump on a 200Tdi runs off the rear groove of a 3 groove crankshaft pulley, not off the water pump.
you need to find a ERR2352 crank pulley for the air con pump to take it's drive from.
this workshop manual page shows the 30tdi air con belt routing, I believe the Discovery 200tdi will be similar
Ahhh... thanks Western, that clears that up then! Looks like I'll be taking a big breaker bar to the scrappies with me then! ;)
Dave.
 Share
