jumping jack Posted December 17, 2010 Share Posted December 17, 2010 Just a quick question are the diff's the same ratio on the front on a '85 110 and a '94 300tdi disco? The 110's diff is making nasty noises and I've got a dead disco sat in the yard. Just wondering if I can get away with swapping the axles over? Thanks Pete Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 17, 2010 Share Posted December 17, 2010 Ratios (3.54:1) are the same. There are many other differences between the two axles though so a complete swap as you suggest may prove easier than trying to interchange parts. Quote Link to comment Share on other sites More sharing options...
jumping jack Posted December 17, 2010 Author Share Posted December 17, 2010 Thanks, thought as much but wasn't sure. Your right, didn't want to be mucking about with different splines etc etc. Quote Link to comment Share on other sites More sharing options...
western Posted December 17, 2010 Share Posted December 17, 2010 . delete please. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 18, 2010 Share Posted December 18, 2010 Same ratios but the hockey sticks might be a different size at the axle/arm bushes and the 110 will have bigger caliper pistons & pads but the discs could be the same, it just depends on the individual vehicle brake specs as regards vented or solid discs. Quote Link to comment Share on other sites More sharing options...
