scabbydisco Posted December 17, 2010 Share Posted December 17, 2010 turned on my headlight switch to driving lights and the headlights flicker on and off in time to the rapid clicking noise under the passenger side dashboard. any ideas guys ? 1994 discovery 300 tdi. changed the alternator last night-was squealing like a banshee and making rattling noises, but still working ok. what a difference! lovely quiet engine! thanks in advance guys. Quote Link to comment Share on other sites More sharing options...
Riz Sauvage Posted December 18, 2010 Share Posted December 18, 2010 turned on my headlight switch to driving lights and the headlights flicker on and off in time to the rapid clicking noise under the passenger side dashboard. any ideas guys ? 1994 discovery 300 tdi. changed the alternator last night-was squealing like a banshee and making rattling noises, but still working ok. what a difference! lovely quiet engine! thanks in advance guys. Sounds like the headlight relay to me, find the clicking relay, clean the contacts, if it persists, swap it out with one of the others if you can, and that should cure it. Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted December 18, 2010 Share Posted December 18, 2010 Would sound to me like a buggered relay, or bad earth to the relay. Not heard of this before though. I think the relay is in the drivers footwell, but Haynes should be able to tell you where it is. Good Luck! Quote Link to comment Share on other sites More sharing options...
karlo Posted December 18, 2010 Share Posted December 18, 2010 Check the plugs on the back of the headlights as these tend to melt and give earth problems. Quote Link to comment Share on other sites More sharing options...
nicedayforit Posted December 18, 2010 Share Posted December 18, 2010 Check the plugs on the back of the headlights as these tend to melt and give earth problems. What he ^^^^^^^^ says. Quote Link to comment Share on other sites More sharing options...
monkeyb0y Posted December 18, 2010 Share Posted December 18, 2010 Yep plugs on back of headlights...I replaced mine with a proper 3pin block for headlights from Halfords ... made a much neater connection using the proper thing... Quote Link to comment Share on other sites More sharing options...
scabbydisco Posted December 19, 2010 Author Share Posted December 19, 2010 thanks for your help guys. Quote Link to comment Share on other sites More sharing options...
Davecrx Posted December 19, 2010 Share Posted December 19, 2010 yer i had the same problem. changed the plug on the headlight and all was good. Quote Link to comment Share on other sites More sharing options...
scabbydisco Posted December 26, 2010 Author Share Posted December 26, 2010 turns out it was due to a defective headlight bulb-main beam had gone out l/h side, but due to daylight driving with lights on didn't notice till someone pointed it out. new bulb=everything in the garden's rosy! Quote Link to comment Share on other sites More sharing options...
