Rivets
Jeff Young
At some point I'll need to restore the galvanized cappings on my IIa 109 SW (they were painted by a PO). Whether or not they need galvanising, they'll need to come off to strip down (and to re-spray the bodywork underneath).
I've done plenty of pop-riveting in my day, but I notice that the parts book specifies solid rivets where both sides of the rivet are exposed. I've probably only formed 3 or 4 solid rivets in my life, but they took about 5min each (as opposed to about 10 seconds for a pop rivet). Does one get vastly faster forming the solid ones after they've done it a few times, or do most people just go with pop rivets all around?
Thanks,
Jeff.
Interesting. I thought one had to "rough-form" the rivet before using the setting tool (or whatever it's called).
I'll have to get a couple sizes of those and play around a bit.
Thanks,
Jeff.
(I assume the sealed pop-rivets still produce more of a bubble than a mushroom on the back side, which I suppose would be more likely to snag clothing, etc.)
Sealed pop-rivets give the closest to a mushroom as you get with a solid rivet, comared to say blind or peel rivets, so you shouldnt get snagged on them
