scot-ish Posted December 22, 2010 Share Posted December 22, 2010 hey, im new, just bought a defender 90 county sw. its a 200tdi on 171k anyays, when i pull off, there is a rumbling noise, it gets a bit louder as the revs increase untill either it goes away, or the revs overpower the rumbling noise. ive been told the half shaft seal is leaking, and have a new on order, so the previous owner has been topping up the diff oil every few weeks. would low level diff oil cause this? or is it something else? when i rev it out of gear, the noise is gone. it makes the noise when the diff/4wd is engaged also. thanks in advance. Quote Link to comment Share on other sites More sharing options...
western Posted December 27, 2010 Share Posted December 27, 2010 are the Oil levels correct main gearbox [ATF] transfer box [EP90] both Diffs [EP90] grease/examine the prop UJ joints for wear & if any evident replace & grease the new ones, also grease the sliding joints. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted December 27, 2010 Share Posted December 27, 2010 Have you checked hand brake adjustmant?? Andy Quote Link to comment Share on other sites More sharing options...
