stuck Posted December 22, 2010 Share Posted December 22, 2010 Have just bought one of these, I know I need to cut the existing "dash" to make it fit but once I've done that can anybody tell me if I can get a DIN mounted CB and a stereo in the "vertical" panel and then a row of Carling switches in the "sloping" panel? I don't want to cut holes in it without knowing! Cheers, Mick. P.S. any pics of your would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Mark Posted December 22, 2010 Share Posted December 22, 2010 Mick, I am in the process of building one for my truck at the moment - it's taken me ages to work out a layout... You can get a shallow din unit into the lower front slot, although my head unit wouldn't fit - my CB (not DIN) would be fine though. The top front slot does not really have enough clearance behind it to fit a din unit in. The top sloped section fits a din head unit in very nicely - so that's where mine is. With a head unit in the top space, clearance behind the top front space gets very tight. I wanted to use the proper plugs on the back of my carling switches, and in order to get enough clearance I put them in the middle of the front panel - thats as high as they can go. If you use crimps on the back of the switches instead, you can fit them into the top slot, but it's still very tight! I can take some pictures of my progress so far if it's of any interest. Cheers Mark Quote Link to comment Share on other sites More sharing options...
western Posted December 22, 2010 Share Posted December 22, 2010 Have just bought one of these, I know I need to cut the existing "dash" to make it fit but once I've done that can anybody tell me if I can get a DIN mounted CB and a stereo in the "vertical" panel and then a row of Carling switches in the "sloping" panel? I don't want to cut holes in it without knowing! Cheers, Mick. P.S. any pics of your would be greatly appreciated. lots of ariations in layout by other customers here Mud console gallery Quote Link to comment Share on other sites More sharing options...
Paul H Posted December 23, 2010 Share Posted December 23, 2010 I have a DIN stereo mounted above a Danita CB in another Din mount on the front face of my mud console with a row of carling switches on the top sloping panel. All fits with no problems. Quote Link to comment Share on other sites More sharing options...
stuck Posted December 23, 2010 Author Share Posted December 23, 2010 Thanks for the help guys. From bottom to top I'll go DIN mounted CB, DIN mounted head unit then Carling switches with crimp connections. Quote Link to comment Share on other sites More sharing options...
Ruuman Posted December 23, 2010 Share Posted December 23, 2010 one thing I'd add when fitting the mud dash is enlarge the hole that all the cables run from the fuse box area. It's a good 2inch wide until it hit's the plastic tray lining that you are covering with the mud dash. hope that makes sense. Quote Link to comment Share on other sites More sharing options...
markyb Posted December 23, 2010 Share Posted December 23, 2010 after i got fedup with cutting holes in that tough plastic i bought the raptor engineering dash, they are wider and he will custom cut all the holes out ready. made light work of it and guaranteed for life can get it in a load of i bought the black one to go with dash http://www.raptor-engineering.co.uk/gallery Quote Link to comment Share on other sites More sharing options...
Mark Posted December 23, 2010 Share Posted December 23, 2010 Not had an issue cutting the plastic tbh. been using an air panel saw and it cuts it beautifully, and very accurately. Quote Link to comment Share on other sites More sharing options...
pooler70 Posted December 23, 2010 Share Posted December 23, 2010 Are there any other alternatives apart from the mud dash and the raptor? Quote Link to comment Share on other sites More sharing options...
western Posted December 23, 2010 Share Posted December 23, 2010 Mammouth4x4 can supply the IronGoat version http://www.mammouth4x4.co.uk/ Boltonbits can supply the ITX version. http://www.boltonbits.net/command-console-p-86.html Quote Link to comment Share on other sites More sharing options...
stuck Posted December 23, 2010 Author Share Posted December 23, 2010 Made a start on mine today and haven't had a problem cutting it. Used an air grinder for the long bits and a pad saw for finishing the corners. Tidy job, happy with it. Quote Link to comment Share on other sites More sharing options...
digger 2 Posted December 24, 2010 Share Posted December 24, 2010 My mud dash in a 300TDi, hope these are usefull to you Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 25, 2010 Share Posted December 25, 2010 Have a look at my blog; I have exactly the configuration you have in mind. It's a tight fit, and using the optional wiring terminal block holders on the backs of the switches makes things worse - they push down a little on the stereo top but using independent wiring terminals would avoid that. The CB may be a bit long, depending on which model you use. Certainly, the Midland 85+ has trouble at the back with the antenna and speaker connectors fouling the main wiring unless you set the DIN mount up so that the entire plastic front is protruding from the mount's front panel, so that you can see the entire white-printed warning label on the top of the CB face. My stereo's rear top corners also contacted the back of the console, but a little trimming sorted that out. Mount the CB and the stereo as low in the unit as possible to avoid that and the fouling of the switch terminal blocks. It's a great mod, though. You can use seven Carling Tech Condura switches with their optional extra mountings in the top slot of the dash unit for a perfect fit within the recess. http://www.nickslandrover.co.uk/archives/1443 Quote Link to comment Share on other sites More sharing options...
